Code tripped after flushing brake fluid- C1247
Old May 9, 2010 | 04:34 PM
C5inHawaii's Avatar
C5inHawaii
2nd Gear
Default Code tripped after flushing brake fluid- C1247
I flushed the brake system yesterday on my 01, and now the "low brake fluid", "Active Handling System Inactive" and "Traction Control Inactive" are showing on my DIC, as well as this code in the diagnostics:
C1247 -Brake Pressure Differential Switch Activated
The brakes work fine, fluid level is just below max on the master cylinder, good and firm brake pedal...everything operates fine.
The only thing I can think of.......When I started the flushing, I sucked most of the old fluid out of the master cylinder and replaced with new fluid, which would have temporarily exposed the low fluid level sensor in the master cylinder.
Could that sensor be "Stuck"? I think that is what is setting off the other warnings.
Does anyone know what "Brake Pressure Differential Switch Activated" actually means?
Thanks.
Old May 9, 2010 | 06:14 PM
vettenuts's Avatar
vettenuts
Had this happen in my C4 once. Manual states to pump slowly and my helper (who shall remain nameless) pumped it rather briskly. I think is shifts something internal to the master cylinder. I ended up pumping the pedal hard a few times without the motor running and the code eventually cleared.
How did you bleed the system?
Old May 9, 2010 | 06:39 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
See if you can clear the DTC and then see if it ges away.
READING YOUR Engine Diagnostic Trouble Codes (DTC)
This procedure should be carried out any time you experience a problem with your C5. Most inexpensive store bought aftermarket code readers will ONLY read power train DTC’s. Reading the DTC’s with the C5 built in code reader will allow you to read ALL the modules in the vehicle.
The Diagnostic Display Mode is entered with the following procedure:
1) Turn on the ignition but don't start the engine.
2) Press the RESET button to turn off any warning messages. (i.e. door open, trunk open ect)
3) Press and hold the OPTIONS button
4) While holding OPTIONS, press FUEL button four times within a 10 -second period.
Initially, the on-board diagnostics go into an Automatic Mode which will cycle through each module and shows diagnostic codes in a pre-set sequence: PCM - TCS - RTD - BCM - IPC - RADIO - HVAC - LDCM - RDCM - SCM - RFA. All codes will be displayed for each module. ( i.e. PCM = 4 codes) If none are present in a given module, you will see No More Codes on the display.
There are two types of diagnostic codes, Current and History designated with a letter suffix, “C” or “H”. A current code indicates a malfunction is present in the module displaying data. A history code indicates a problem existed sometime in the last 40 or 50 ignition cycles. When not accompanied by a current code of the same number, it's potential evidence of a previous problem, now resolved, that was not removed by clearing the codes. More likely it's an indication of an intermittent malfunction.
Intermittent codes are the most challenging of the diagnostics. An intermittent code may have happened once, may have happened more than once but is inconsistent or may be happening on a regular basis but not at the time the codes are displayed. History codes can also be caused by a current malfunction in a system that is not operating at the time codes are displayed. An example is the rear window defogger which doesn't operate until the Body Control Module detects engine rpm. For history codes set by a module that does not operate with the key on and engine off, a special diagnostic tool called a Scan Tester is necessary to properly diagnose the malfunction.
Once the system has displayed all modules, it goes into the manual mode which allows selection of each module using combinations of Driver Information Center buttons. Manual mode can also be entered during the automatic sequence by pressing any button except E/M. Once the display shows Manual Diagnostics, select a module by pressing the OPTIONS button to go forward or the TRIP button to go back. Once a module is selected, a code is displayed, and if more than one are present; press GAGES to go forward or FUEL to go back.
To exit the diagnostic mode at any time, press E/M. If you want to erase codes in a given module, press RESET To reset the codes once in manual mode, press and hold RESET until it displays NO CODES Press OPTIONS to go to the next module. Repeat the steps until you have reset the codes in all the computer modules.
NOTE!! Only reset the codes IF you want to - it is NOT necessary to do this. Clearing a code does not repair a problem. You are simply erasing the evidence of it in the module's memory. If you clear the code/s, and extinguish the Check Engine Light, your emissions status ready will NOT allow you to pass an emissions test until you have completed the required driving cycles. There are a few body module DTC’s that if set will prevent the module from operating properly. Once the DTC is cleared, the module will return to full function. This is not true for power train DTCs.
If you have never read and cleared your codes, there will probably be a lot of old history DTCs. It is recommended that you clear your codes and see if any come back during a driving cycle. Those are the ones that you need to concentrate on diagnosing.
Once you have the codes, the next question is: What to do with the information?
First, consult the factory service manual. Any serious C5 Do-It-Yourself owner should invest in the Corvette Service Manual of the appropriate model year. The Service Manual is really a requirement if you want to understand and work on your C5.
NOTE and a WARNING. You can read the DTCs while the engine is running. I pull mine up all the time while driving.
WARNING. Don’t become distracted while reading DTCs while your driving and cause an accident!!!!! Use common sense and drive safe.
These are some very good C5 Diagnostic Trouble Code (DTC) explanation web sites!!! They also explain how to read the DTCs
Here are some very good sites that explain what DTC mean:
http://www.gearchatter.com/viewtopic11755.php
http://www.obd-codes.com/trouble_cod...d-ii-codes.php
Make sure to include the H or C suffix when you post your DTCs!!
Old May 9, 2010 | 07:26 PM
C5inHawaii's Avatar
C5inHawaii
2nd Gear
I used a vacuum bleeder.
I cleared the codes, but they just came right back. After finding some other posts on this subject, I went out and pulled the connector off the sensor, started it up, and no warnings.....so it is the sensor in the master cylinder. Maybe some driving time with some hard stops would "reset" the sensor?...or unstick something???
For now, I'll just leave it un-plugged.
Old May 9, 2010 | 08:44 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Do some HARD stops and activate the antilock system. Maybe there air still in it. That will cause it to pass the air out to the master
Old May 9, 2010 | 11:37 PM
byronhunter's Avatar
byronhunter
This problem has come up before when brakes were bled with the Ign Switch on.
Old May 9, 2010 | 11:41 PM
byronhunter
From the Manual:
Conditions for Clearing the DTC
The condition for the DTC is no longer present and the DTC is cleared with a scan tool.
The EBCM automatically clears the history DTC when a current DTC is not detected in 100 consecutive drive cycles.
To Code tripped after flushing brake fluid- C1247
