How do I drain my A/C system
Old May 9, 2010 | 10:32 PM
00cls1camaross's Avatar
00cls1camaross
Default How do I drain my A/C system
I need to drain my A/C system so I can replace a couple of the hard lines. Is there a certain way to do this or do I just undo the line and let it drain? Is there a bleeder screw somewhere?
Old May 9, 2010 | 10:34 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
You need to take it and have it vacuumed down....if you want it done right
Old May 9, 2010 | 10:41 PM
00cls1camaross
That's not an option since the car has no motor in it lol.
Old May 9, 2010 | 10:48 PM
ipuig's Avatar
ipuig
St. Jude Donor '09
The A/C system is under pressure even when it's not in operation. It does have charging and evacuation connections but they require specialized fittings. If you do not know much about it you should probably leave it alone. The system will have to be evacuated prior to recharging with new refrigerant and compressor oil.
Old May 9, 2010 | 10:52 PM
00cls1camaross
Originally Posted by ipuig
The A/C system is under pressure even when it's not in operation. It does have charging and evacuation connections but they require specialized fittings. If you do not much about it you should propbably leave it alone.
I need to change out one of my hard lines before the motor goes back in. I don't have the clearence to take it out later with my turbo kit.
Old May 10, 2010 | 01:10 AM
lucky99's Avatar
lucky99
Just crack the line open it will drain itself. After you remove the line go outside look up at the sky see if there is a hole in the ozone above your car. The right way is to use a recovery system they are portable.
Old May 10, 2010 | 04:36 AM
00cls1camaross
Where can I buy this recovery system and how much are they?
Old May 10, 2010 | 05:17 AM
vettenuts's Avatar
vettenuts
Do you have access to a trailer or won't the car roll? I would be careful here, this system is under pressure and you can get hurt doing things incorrectly. Also, pick up a new drier since the system will be open and a new line installed once you get it emptied.
Old May 10, 2010 | 08:15 AM
pewter99's Avatar
pewter99
pewter99's Avatar
pewter99
much more than possibly renting one or trailering your car to an AC shop
Old May 10, 2010 | 04:37 PM
00cls1camaross
I curretly don't have any wheels on the car till my new one show up lol.
Old May 11, 2010 | 05:41 PM
ammo6's Avatar
ammo6
Per EPA regulations, it is illegal to vent R134a refrigerant to the atmosphere. This is the refrigerant used in automotive applications on newer vehicles. It needs to be properly recovered. Unless you have a the equipment to recover the refrigerant I would recommend that you find a way to have it done. Your local house A/C technician may only be 608 certified, that means he/she cannot to cars, need to be 609 certified for automotive applications. However, they can be certified in both. Give a call and they may come to your house and do it for you. There is a stiff fine for anyone knowingly venting refrigerant and is caught.
The most you can do at home is add refrigerant when your system is low, but once again, unless you know what you are doing you can introduce non-condensables into your system causing issues and eventually A/C failure.
JMHO
Old May 11, 2010 | 05:51 PM
hotwheels57's Avatar
hotwheels57
Check with rental supply vendors or maybe NAPA, AUTOZONE, CHECKER AUTO. The latter usually rent out tools of all types, maybe they have the portable vacuum recovery system available.
Call some local automotive a/c shops for their recommendations because the car is inoperable.
If you don't do it correctly, you're inviting failure/moisture/contaminants into the a/c system. Then the replacement of your hard lines will be in vain.
Old May 11, 2010 | 10:23 PM
byronhunter's Avatar
byronhunter
00cls1camaross, it's begining to look like you need to be a rocket scientist to evacuate the AC system!!!!!!! I have to ask one question, if you have a bad hose, has it already evacuted itself?
Old May 12, 2010 | 08:26 AM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
It's probably already discharged of refrigerant, but not evacuated.
Evacuation is the removal of any air in the system, with a vacuum pump,
before the refrigerant is recharged into the system.
Old May 12, 2010 | 08:53 AM
Jewjenk's Avatar
Jewjenk
The most you can do at home is add refrigerant when your system is low, but once again, unless you know what you are doing you can introduce non-condensables into your system causing issues and eventually A/C failure. JMHO
Also without the proper equipment, you can be blinded or/and suffer permanent lung damage. SO get a professional to remove the R134. But like others have said it is probably empty of refrigerant and simply needs to be evacuated.
Old May 12, 2010 | 09:50 AM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
It should be pretty easy to get to one of the valves on the hard line where you normally add freon and open it. It's basically the same kind of valve as you have on a valve stem on a tire.. Just be careful. You can also go to walmart or wherever and get the tool you usually use to fill an AC system and just not put a can on it.. Leave the valve closed when you connect it to the car and slowly open the valve to release whatever is left in there.
I guess its technically illegal to let freon go into the atmosphere, btw. Sooo whatever, your call.
Also, DO HAVE A PROFESSIONAL RE-FILL THE SYSTEM. The whole system needs to be put under vacuum long enough to cause any and all liquid water to turn to a vapor and escape before you start adding freon.
To How do I drain my A/C system
Old May 12, 2010 | 10:39 AM
byronhunter
Wow!! Who knew that? But he ask about "draining" the system, not a word about what to do when it comes time to recharge it!
Old May 12, 2010 | 11:17 AM
Quicksilver Vert 01
I caught the "draining" part too. At atmospheric pressure, liquid R-134a vaporizes at -15 degrees F. It would have to be a COLD day to drain it!
Old May 12, 2010 | 09:04 PM
00cls1camaross
I have a damaged line but it's not leaking.
