Alignment question
Old May 13, 2010 | 09:13 AM
aschiftner's Avatar
aschiftner
Default Alignment question
I had a local shop tell me that can get a 4 wheel alignment prior to putting my new tires on with no issues.
Is this true? Thanks. R/ Al
Old May 13, 2010 | 11:38 AM
postwhore's Avatar
postwhore
As long as the tire pressures are correct, sure
Old May 13, 2010 | 12:37 PM
aschiftner's Avatar
aschiftner
The tires are just worn on excessively on the insides. R/ Al
Old May 13, 2010 | 12:39 PM
postwhore's Avatar
postwhore
you will be fine
Old May 13, 2010 | 12:46 PM
Dave68's Avatar
Dave68
I asked an alignment shop manager (here in San Diego - very well known shop) if I should wait until I bought new tires and he advised me to have the alignment done immediately after having the new tires installed.
Old May 13, 2010 | 12:51 PM
87SAM's Avatar
87SAM
I'm in the do it with the new tires group.
Old May 13, 2010 | 01:03 PM
aschiftner's Avatar
aschiftner
Awesome!! Thanks.!!
Old May 13, 2010 | 04:27 PM
acrace's Avatar
acrace
If you are going to get the car aligned with new tires, I would make sure that you have pics or can describe your old tires. You mention that the current tires on excessively worn on the inside. That would suggest to me that either there's too much negative camber for how the car is used or excessive toe (or a combination of both).
A good alignment tech can look at tires, look at the "before" alignment readings, and make recommendations on how the car should be set up to maximize the life of your tires.
The GM spec has a lot of latitude in what's "acceptable", so make sure that your alignment shop has all the information needed to do a good job.
Old May 13, 2010 | 04:47 PM
wcsinx's Avatar
wcsinx
I have seen misworn tires throw off alignment readings.
Old May 13, 2010 | 04:53 PM
cdnguyred88's Avatar
cdnguyred88
Old May 14, 2010 | 03:48 PM
Dream Tire's Avatar
Dream Tire
coming for a guy who does alignments
Old May 14, 2010 | 04:02 PM
dankhts's Avatar
dankhts
he seems to know - I just left Dream Tire after having my C5 aligned ... listen to the experts.....mine drives good as new now BTW...
Old May 14, 2010 | 04:20 PM
Dream Tire's Avatar
Dream Tire
Thanks Dan
Glad to hear that shes back to what she use to be
Old May 14, 2010 | 06:13 PM
aschiftner's Avatar
aschiftner
Default Alignment update
Thanks for all the reply's. Getting it done prior to getting the tires was only going to be for convience. However there will be no alignment today.... After putting it on the rack my front passenger tire/wheel has play in it. They recommend I get the outer tie rod replaced prior to the alignment. I have one on order and will replace upon arrival.
THANKS AGAIN!!! R/ Al
Old May 14, 2010 | 06:25 PM
aschiftner's Avatar
aschiftner
Are all alignments the same?
My car was on a lift that was raised about 4 feet. THey then jacked the car while still on that lift to raise the wheels/tires were off the ground. They then hooked up some sort of contraption to the wheels. It appears that those were going to shoot a laser to get straightness readings. When the play in the wheel/tire was found things ended there. I'm going to do some surfing on the procedure. Thanks. R/Al
Old May 15, 2010 | 06:15 AM
dieseldave56's Avatar
dieseldave56
Default Align for driving style or tire wear.........
Alignments are a numbers game that you can set the rules for. The alignment can be for a driving style or optimum traction set up or for a DD's best tire wear and comfort ride. As mentioned before , there is a lot of tolerance in the alignment specifications.
An experienced alignment man is also a great asset.
Old May 15, 2010 | 10:54 AM
postwhore's Avatar
postwhore
what kind of wear ?
I'm thinking it would have to be pretty extreme
coming from a guy who used to do alignments for years
To Alignment question
Old May 16, 2010 | 10:53 AM
wcsinx's Avatar
wcsinx
what kind of wear ?
Typically inside/outside edge wear from bad toe and/or camber settings
You do an alignment with the assumption that the tire, as viewed front to back, is a rectangle. If in truth it's trapezoidal from an uneven wear pattern, then that can easily throw off your readings.
Old May 16, 2010 | 04:44 PM
postwhore's Avatar
postwhore
I'd think it'd have to be pretty extreme to change it very much.
I never really checked back then .
I was usually doing a set of new tires before the alignment though.
Old May 16, 2010 | 10:05 PM
aschiftner's Avatar
aschiftner
Well, the tires should be in tomorrow. The outer tie rod will not be until Tuesday. I think I'll be getting the tires on first. Thanks guys. R/ Al
