Best tires ?
Old May 16, 2010 | 10:29 PM
Snoman2's Avatar
Snoman2
Default Best tires ?
OK go ahead and yell at me if this is a beat to death Thread!
I did search but never really found anything, It's time to but some new rubber on the C5 what have you folks found is the best tire to go with? Don't mind spending the $1300+ for the Goodyears run flats but if another tire out these is better I'd sure like to hear about it
Old May 16, 2010 | 11:13 PM
lucky131969's Avatar
lucky131969
Old May 17, 2010 | 02:26 AM
C54ever's Avatar
C54ever
Get this. When I bought my 2001 it had two worn out Michelin sport plus on the front and a worn out Michelin run flat on the left rear and a fairly new Proxes T4 on the right rear!
I ended up putting Goodyear F1 GSD3's on and it was like a new car. They are the stickiest tires I have ever seen. Not recommended for cold weather but who drives their vet in the snow anyway? P.S. They are not the run flats!
Old May 17, 2010 | 05:48 AM
Atok's Avatar
Atok
Michelin PS2. End of story.
Old May 17, 2010 | 07:13 AM
Boodieman's Avatar
Boodieman
Old May 17, 2010 | 07:27 AM
LoneStarFRC's Avatar
LoneStarFRC
The black ones that look the prettiest.
Old May 17, 2010 | 08:18 AM
JCamaro's Avatar
JCamaro
Yep....they are the BEST....but they're pretty much the most expensive as well.
Old May 17, 2010 | 09:05 AM
dougbfresh's Avatar
dougbfresh
Guess you don't search very well then-this has been dozens of times.
Old May 17, 2010 | 02:19 PM
Jims Z06's Avatar
Jims Z06
When it comes time for me to try new rubber, I'm going to try Vredestein Ultrac Sessanta
http://www.vredestein.com/Onlineadvi...s_Controle.asp
Alot of info on these on the net...type in vredestein. Good Luck !
Jim
Old May 17, 2010 | 02:36 PM
tail_lights's Avatar
tail_lights
Been very happy with my Bridgestone Potenzas
Old May 17, 2010 | 02:52 PM
Dave68's Avatar
Dave68
....not anymore! See
http://www.caranddriver.com/reviews/...mparison_tests
Like C54ever, I have Goodyear GSD3s and they are the best tires I've ever had, bar none. They were the winner of another Car & Driver tire test, a few years ago but someone posted that Goodyear is discontinuing them. I sure hope the next generation is in the works.
Old May 17, 2010 | 04:10 PM
overBlown's Avatar
overBlown
Jim
This. I have them on my Z and can't say enough good things about them. Plus they are no where near the outrageous price of the PS2's and others.
Old May 17, 2010 | 04:54 PM
cdnguyred88's Avatar
cdnguyred88
Old May 17, 2010 | 10:29 PM
Snoman2's Avatar
Snoman2
Thanks for the info I will continue my research
Old May 19, 2010 | 06:48 PM
lionelhutz's Avatar
lionelhutz
Best tire for what use?????
I don't agree. Too much money for the tire. You can get 80 to 95% of the PS2 performance for around 30% to 60% of the money.
I'm running Bridgestone RE-11''s and I like them so far. I have 19" rims though so my choices are more limited. I have stock rims too and they came with Kumho's and when I had them on I though they were pretty good too. Actually they seemed to stick pretty good.
Peter
Old May 19, 2010 | 07:12 PM
Darion's Avatar
Darion
I have PS2's and like them alot. I switched out my Goodyear run flats with about 1000 miles on them and the difference was big. Much less tire noise, better dry and wet traction/control and improved ride, all subjective but my still my opinion. I liked them well enough that when I bought my CCW wheels I had CCW put PS2's on.
All that being said, for the cost I don't know if I would get them again, but I drive the car so little who knows when I'll need new tires.
Darion,
Old May 19, 2010 | 07:13 PM
Uglymarine's Avatar
Uglymarine
Default If Run-Flats
Check Tire Rack. You can compare tires against each other. I noticed one day that they also list tire weight in the comparison. So unsprung weight reduction helps performance no matter how small the weight. Personally I use the Michelin Pilot Sport AS ZP...........It is a run flat ran long for the tires that I've had on the car. Those were only about 1 lb heavier than the non-runflats that I compared to at the time. I notice the new Plus is supposed to be the same tire with higher mileage expectation. The best wet tire I ever had on the car was the Firestone firehawk runflat. But they were too expensive. I really didn't like how they looked as well either.............Oh Yeah when I first installed the Michelins on my car and had it aligned I went on Tail Of the Dragon US 129 in the North Carolina Tenn. Mountains Motor Cycles were pulling over to let me by.......Not the sport bikes mind you. When I used to ride bikes I'd never have pulled over for any car. They simply wouldn't have been able to keep up in the mountains.....Devil Dog that is what the vet calls him because he has some real attitude actually got queazy. He only weighs 6.5 lbs. I didn't tell the Vet that is what the Germans called the US Marines in WWII. I'm so proud of that Dog.
To Best tires ?
Old May 19, 2010 | 09:02 PM
ifly2's Avatar
ifly2
I've been running Goodyear F1 UltraPerformance All seasons. I mainly Travel with the Vette but have driven twisties at at high rate of spirit (as I would have ridden them on my Ducati) and experienced no incidents but a lot of confidence in these tires even in the wet. I don't race so Ican't speak to that end. But they're pretty quiet and I'm getting good wear so far. 10,000 right anwsers can't be wrong. Right?
Good Luck
Colin
Old May 20, 2010 | 12:03 AM
zoomz's Avatar
zoomz
Goodyear GSD3's by far for wet weather and dry traction .
My car with these tires will move your eye ***** in their sockets rocking big looping turns ,, haha . Its the strangest thing ive ever felt
Old May 20, 2010 | 09:39 AM
LoneStarFRC
Originally Posted by zoomz
Goodyear GSD3's by far for wet weather and dry traction .........
For stock replacement tires, these should be at the top of anyone's list. I had them at one point and they are truly outstanding in the rain.
Just wish GY made'em bigger (wider) in the 18" version. I need traction.
