Easy Shift Knob Pin Removal Tool
Old Mar 19, 2002 | 10:57 PM
chuckster's Avatar
chuckster
Default Easy Shift **** Pin Removal Tool
I have posted before about this. But I never took a picture of it. I had a stubborn pin that had me :cuss :cuss
I decided there has to be a better way. I could get a pair of Vice-Grips on it no problem but could not get enough leverage on it pulling up. I made a slide hammer approach using a 5lb Barbell weight and a threaded Eye Bolt.
Just remove the adjusting bolt from the end of the Vice-Grips and replace it with an Eye Bolt of the same thread. But before you attach it to the vice grips put it through the hole in the barbell plate. Once attached and clamped on the pin all it takes is 2 or 3 nice raps up with the barbell plate.
here is a picture if you need 1000 more words.. :D
Old Mar 19, 2002 | 11:10 PM
JohnS's Avatar
JohnS
Default Re: Easy Shift **** Pin Removal Tool (chuckster)
Great idea! I actually didn't have any problems using the two screwdriver method though.
JohnS
Old Mar 19, 2002 | 11:13 PM
chuckster's Avatar
chuckster
Default Re: Easy Shift **** Pin Removal Tool (JohnS)
JohnS
Yeah some I heard you could pull out with tweezers and other you needed blasting caps.
Guess which one I had?
Old Mar 20, 2002 | 12:14 AM
MDT's Avatar
MDT
:yesnod: Nice rigging, chuckster. :yesnod:
Good luck.
Mark
[Modified by MDT, 10:15 PM 3/19/2002]
Old Mar 20, 2002 | 12:52 AM
Ron Price's Avatar
Ron Price
I'm impressed!! :yesnod: :yesnod: :yesnod:
I will file this in my memory to be used when needed. :smash: :smash:
Old Mar 20, 2002 | 01:13 AM
VetterMan's Avatar
VetterMan
chuckster--
You get the prize for most innovative methodology for pin removal.:hat
Bet you're a surgeon.:lol:
:cheers:
VetterMan
Old Mar 20, 2002 | 05:17 AM
Fast Lane's Avatar
Fast Lane
CI 3-4-5-6-7-8-9-10 Veteran
:eek: Hope my pin isn't that stubborn. You must be a denitst. :smash:
Old Mar 20, 2002 | 12:08 PM
Al '92's Avatar
Al '92
I clamped down on the pin with vice grips and used a screwdriver between the vice grips and the shifter to lever the pin out. I also use a small piece of wood to protect the shifter during removal. Worked like a charm and I got the tip right here on the forum. :cheers:
Old Mar 20, 2002 | 09:50 PM
sunvet's Avatar
sunvet
You've been doing this stuff too long! :crazy:
Old Mar 20, 2002 | 09:54 PM
SteveL2's Avatar
SteveL2
Forgive me for languishing praise, but having wrestled with one of these pins, this solution is simply brilliant! :cheers: :cheers:
Now, make a cheaper version and go sell it to those who aren't smart enough to read the Forum.
:jester
Old Mar 20, 2002 | 11:53 PM
chuckster's Avatar
chuckster
Default Re: Easy Shift **** Pin Removal Tool (SteveL2)
Awe Shucks
Thanks guys... :bb
Old Mar 21, 2002 | 02:18 PM
2kbluestreak's Avatar
2kbluestreak
Shows there is more than one way to skin a cat. The vice grip, screwdriver and block of wood worked fine for me. Before re-installing, I took a couple of easy swipes on the aluminum key with a fine file. It comes out a lot easier now. :cheers:
Old Mar 21, 2002 | 03:42 PM
MySea6's Avatar
MySea6
Dayum chuckster, you don't mess around :D :lol: :D
You really should try the two screwdriver method though. It has worked flawlessly for me on 7 or 8 installs. No matter how tight the pin is. :cheers:
Old Mar 21, 2002 | 05:28 PM
chuckster's Avatar
chuckster
Default Re: Easy Shift **** Pin Removal Tool (MySea5)
I did not like using the stock **** as a fulcrum for all that leverage. Also as mentioned some pins are jammed in tight. Mine was in so hard that after I pulled it out I could see where it was too big and they just pounded it in at the factory. There was a big mark on it. I even had to dremel it down a little just to get it to seat back in without using a pile driver. :D
Anyway. the Eye Bolt cost me $.89 and I had the barbell plate. It took exactly 2 whacks and pop!
Old Mar 21, 2002 | 06:09 PM
BikerDuude's Avatar
BikerDuude
I thought I was the only MacGuyver on this board..... :lol:
Old Mar 21, 2002 | 07:58 PM
StormCrow's Avatar
StormCrow
Cruise-In III Veteran
Thank you, thank you, thank you. I just got my new shift **** last night and after a lot of swearing, I finally gave up. I'll take another crack at it tonight using this method. :)
I tried the wood block method and was too scared of damaging the stock shifter.
Old Mar 21, 2002 | 08:14 PM
sunvet's Avatar
sunvet
Default Re: Easy Shift **** Pin Removal Tool (StormCrow)
After I went to Sears to get a different pair of vice grips with narrower jaws, I was able to get the pin out by putting a screw driver through the vice grips and pounding up with a hammer, being careful not to hit the hammer on anything!
Old Mar 21, 2002 | 08:22 PM
SteveL2's Avatar
SteveL2
Can you elaborate on the "two screwdriver method "? Thanks. :cheers:
To Easy Shift Knob Pin Removal Tool
