Need Help: Brake line replacement
Jun 7, 2010 | 10:09 AM
St. Jude Donor '08
I recently got a set of Goodridge brake lines for my 97 and I'd like to look at a set of install instructions before i go tearing into my car. Anyone have a tutorial?
Jun 7, 2010 | 10:47 AM
just change one at a time and make sure the fluid reservoir stays full
then bleed
Jun 7, 2010 | 10:50 AM
St. Jude Donor '08
how do you remove the upstream part of the line? Does the little clip need to come off?
Jun 7, 2010 | 11:13 AM
St. Jude Donor '09-'10-'11
Quote:
Originally Posted by
TheRadioFlyer
If you check in your service manual it tells you what all needs to be done under
Front Brake Hose Replacement (J55) . Why are you replacing them?
Jun 7, 2010 | 11:18 AM
St. Jude Donor '08
Eric D
If you check in your service manual it tells you what all needs to be done under Front Brake Hose Replacement (J55) . Why are you replacing them?
i'm referring to the connection between the rubber and hard lines. There's some kind of clip there i'm not sure how/if to remove.
Jun 7, 2010 | 11:57 AM
it slides out
grab and pull
Jun 7, 2010 | 01:36 PM
St. Jude Donor '08
postwhore
it slides out
grab and pull
After much grumbling and cursing, I finally got it out and installed the new line.
Do you guys reccomend bleeding each line as you install them, or should i install all 4 lines, then bleed?
Jun 7, 2010 | 03:21 PM
change all then bleed.
furthest rear from master, then other rear, then furthest front, then other front.
make sure to keep filling master.
do not get any fluid on paint.
i would have a friend pump and hold for me.
i would use a glass jar with clean fluid and hose.
Jun 7, 2010 | 03:50 PM
TheRadioFlyer
What did you use for torque values?
Jun 7, 2010 | 04:42 PM
St. Jude Donor '08
Eric D
I guessed. I do not have a torque wrench so i just tightened until i felt the washer had crushed itself.
