Replacing AC Delco battery
Old Jun 14, 2010 | 01:18 PM
03sixspeed's Avatar
03sixspeed
Default Replacing AC Delco battery
My 2003 coupe battery just died yesterday on a cruise with the club I belong to. I have always used a battery tender and the car has always started fine. When the battery was pulled it was swollen. Had to buy a group 75 battery at Sears. This new one is not an AGM style. Where is the best place to find matting to place under the new one to absorb any leaking acid that could occur.
Old Jun 14, 2010 | 01:26 PM
DeeGee's Avatar
DeeGee
Don't worry too much
The original AC Delcos that leaked are all gone now. The latest batteries are redesigned and shouldn't cause a problem.
If youre really worried you can get them online
Old Jun 14, 2010 | 01:28 PM
03sixspeed's Avatar
03sixspeed
The new battery I bought at Sears is the Gold series, and not AGM type, that is why I am asking about battery mat.
Old Jun 14, 2010 | 01:37 PM
DeeGee's Avatar
DeeGee
The reason we're all paranoid about leaks here is the original AC Delcos had a design fault. If you over torque'd the battery leads the case could crack and leak on the PCM. It caused many problems with the computers and the HVAC.
The latest crop of batteries don't have that issue so the chances of a leak are reduced.
Old Jun 14, 2010 | 03:14 PM
Win Heger's Avatar
Win Heger
St. Jude 15 Year Donor
St. Jude Donor '11 thru '26
The battery just died in my '03, it had been replaced twice, under warranty, within a few months of my buying the car. When I pulled it out I saw that it was a 78 series not the 75 that is listed as OE. I got a Delco 7 yr for replacement but stayed with the 78.
Win
Old Jun 14, 2010 | 09:42 PM
bighank's Avatar
bighank
Default My 98 uses a 78 think they are a little heftier than a 75
Win
I have replaced the Delco with a Sams battery. Believe it is Eveready.
Had the acid leak and had to redo the vacuum hoses and check valve.
Good idea to remove the battery tray and flush with a boric acid bath mixed up in at least a gallon of water. Let dry then paint any surfaces the acid got to.
BIGHANK
Old Jun 14, 2010 | 11:13 PM
03sixspeed's Avatar
03sixspeed
Did not find any evidence of leaking acid or any damage under the old battery. I was just concerned that I was not using an AGM style battery that came with the car. I am aware that others have had issues with non-agm batteries and was just trying to get info on ways to protect my car from future issues with the Sears replacement.
Old Jun 14, 2010 | 11:44 PM
ALLEGRO's Avatar
ALLEGRO
I am still running my 2003 AGM battery, so obviously, they do last a long time. BUT, at nearly $200, not sure it is worth it. Get a battery mat and roll the dice
Old Jun 15, 2010 | 12:40 AM
Camjamsdad's Avatar
Camjamsdad
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
BIGHANK
Sams sells Energiser batteries. And Optimas. Optimas are a division of Interstate.
Mine was a Group 78. I went with a Red Top Optima even with all the hard luck stories out there. I had minor acid damage from the Platinum battery that Advance sells. Half a box of baking soda neutralized the acid then rinsed it out with the garden hose.
Old Jun 15, 2010 | 03:39 PM
Dave68's Avatar
Dave68
I replaced my OEM AC Delco AGM battery with the AC Delco Professional 7YR battery. Really, there is no need to worry about leaking batteries. That last leakers were made in 2000 and all non-AGM batteries installed in C5s after 2003 are of superior design.
You can buy a mat from Ecklers but in all likelyhood, you will never need it.
Old Jun 15, 2010 | 03:42 PM
87bob's Avatar
87bob
Veteran: Coast Guard
Default Me too!
I am currently cleaning up a battery acid spill from the P.O.. I removed the battery battery, base plate, PCM, Tach module. All had dry acid on them. I was told by a GM world class tech if left it will eat it way through the case of the PCM, cables, and vacuumm lines (for the AC). He suggested I use the spray foam battery cleaner. Clean it all and repaint the frame where the acid ate the paint off. I have a Wheelhorse Lawn Tractor. The battery sits down in a case that has a plastic tube that drains off any potential acid spills why in the hell GM didn't think of that is beyond me.
Old Jun 15, 2010 | 07:30 PM
03sixspeed's Avatar
03sixspeed
Went to my local GM dealer today to ask about the AGM battery and they told me they don't even have AGM batteries in the listing for replacement.
Old Jun 16, 2010 | 12:34 PM
bobby777's Avatar
bobby777
Get an Optima 75/25--all worrys gone--
Old Jun 17, 2010 | 09:54 AM
kenc5's Avatar
kenc5
I just got an Optima red top. Almost 7 years for the Delco.
Old Jun 17, 2010 | 09:59 AM
lucky131969's Avatar
lucky131969
So after almost 7 years of faithful service, why didn't you go with another Delco?
Old Jun 17, 2010 | 12:22 PM
FirethornC5's Avatar
FirethornC5
I replaced mine with ACDelco Part Number: 78-6YR. This is a 6 year battery with 700 cca and costs lest than Part Number: ACD78-60 which is a 5 year battery with only 670 cca. Sometimes, just can't figure GM's pricing out?
Old Jun 18, 2010 | 03:32 AM
Rebel 1's Avatar
Rebel 1
I only use Delco batteries. Always had good service out of them
To Replacing AC Delco battery
Old Jun 18, 2010 | 09:21 AM
kenc5's Avatar
kenc5
Yesterday 08:54 AM
Because I couldn't find a Delco in stock. Everything was a special order wait a week.
Old Jun 18, 2010 | 09:48 AM
Win Heger's Avatar
Win Heger
I had no sign of acid leak when I pulled the battery, I had checked when the OE was replaced and the failure was not due to leaking. Got lucky, I think.
Win
Old Oct 4, 2010 | 12:16 AM
ImpalaTommy's Avatar
ImpalaTommy
4th Gear
Another good battery p/n is 78-7yr which is 800cca and costs very little more.
