Headlights stopped working
Old Jun 19, 2010 | 02:51 PM
Marshall Goby's Avatar
Marshall Goby
Default Headlights stopped working
I just purchased a 1998 Corvette Pace Car. After bringing it home, the highlights do not open automatically nor do the lights turn on. The dash lights do come on when the headlight switch is turned on. Any ideas how I repair the problem? Please help!
Old Jun 19, 2010 | 03:06 PM
lucky131969's Avatar
lucky131969
The headlight control module is under the right headlight.
Old Jun 19, 2010 | 03:35 PM
Marshall Goby
How do you suggest I proceed? Do you believe it is the control module that is bad? What would you do to isolate the problem?
Old Jun 19, 2010 | 03:40 PM
lucky131969
No I'm not suggesting that the control module is bad, I'm just making you aware of the location. I provided the schematics, so you can see everything in the system, and be able to check fuses, voltage, ground, etc. Do you have a meter, and can you read the schematics?
Old Jun 19, 2010 | 06:34 PM
thechosenone's Avatar
thechosenone
check the fuse!
Old Jun 19, 2010 | 11:06 PM
C5PaceCar's Avatar
C5PaceCar
Marshall, Congratulations on your '98 Pace Car. Coincidentally I was driving mine home tonight and when I got home in the garage and turned the lights off, neither light retracted. So if anyone can throw in some help on this problem while you are helping Marshall I would appreciate it.
Old Jun 20, 2010 | 10:02 AM
Marshall Goby
Thanks for the feedback. I can read the schematics and do have a meter.
Old Jun 21, 2010 | 10:48 AM
lucky131969
Excellent, you find the issue in no time.
To Headlights stopped working
