Disconnecting battery
Old Jun 23, 2010 | 01:44 PM
03BlkZ's Avatar
03BlkZ
Default Disconnecting battery
This is a really stupid question but I have to ask since I dont know. Will removing my battery completely affect my Dyno tune?
Old Jun 23, 2010 | 01:54 PM
lucky131969's Avatar
lucky131969
No.
Old Jun 23, 2010 | 03:52 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Lucky
Couldnt you have given a simpler answer??
I hate long drawn out answers!
BC
Old Jun 23, 2010 | 03:53 PM
lucky131969
Originally Posted by Bill Curlee
Lucky
BC
I tried to make it shorter, but the site would not let me post, so I had to throw a period in there...
Old Jun 23, 2010 | 04:23 PM
87bob's Avatar
87bob
Veteran: Coast Guard
Just be sure to pull the negative post first. Pulling the positive can cause a surge and fry components. Before someone wants to argure or flame me about this a GM Certified Wold Class Tech told me this
Old Jun 23, 2010 | 05:04 PM
STL94LT1's Avatar
STL94LT1
I install over 2000 batteries a week and the positive is always secured first.
Old Jun 23, 2010 | 05:25 PM
lucky131969
....wow....did you get to touch him?
Old Jun 23, 2010 | 05:47 PM
imavettegirl's Avatar
imavettegirl
what wold is he from?
Old Jun 23, 2010 | 06:21 PM
lucky131969
what in the wold are you talking about?
Old Jun 23, 2010 | 06:29 PM
03BlkZ's Avatar
03BlkZ
Thanks guys! Like I said it was a stupid question and thanks for the simple answer!
Old Jun 23, 2010 | 08:26 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
On a more serious note, your PCM memory is contained in a FLASH Memory Chip. Once it written, its permanent unless it over written using EFI Live, HP Tuners or the TECH II. Your tune is safe.
Disconnecting the battery can effect the PCM "LEARNED" information. Things like, Long Term Fuel Trims and Idle air adjustments. All those things will rebuild or learn with in a couple driving cycles. You may also loose some of your Set MEMORY settings and your fuel mileage information,
Old Jun 23, 2010 | 09:34 PM
imavettegirl
the GM Certified Wold Class Tech only works on wold class corvettes.
Old Jun 29, 2010 | 07:22 PM
Kevin G's Avatar
Kevin G
No such thing as a stupid question. On a side note, the first time I disconnected and reconnected my battery I got a flock of codes upon restart. Repeated the process only the second time cleaned the threads and the terminal. No codes.
Old Jun 29, 2010 | 08:32 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
WTF is a "Wold" class tech? Is that someone that flunked out of the official GM course and got a certificate online?
To Disconnecting battery
