Car runs terribly after header install
Old Jun 26, 2010 | 10:28 AM
WELEPRO's Avatar
WELEPRO
Default Car runs terribly after header install
Hey all,
Yesterday I finished the install of my LG Street series headers. Now, the car runs really badly....so somehwere something went wrong. I expect it to run rich until it gets tuned, but it is missing, has intermident acceleration/power, and idles extremely low(400RPM).
The only things that didn't go according to plan, was the replacment of 2 wires I had to remove to get the drivers side header in place. They were near the collector, possibly above it. One black wire, and one silver/mesh stlye wire, grounded in the same area(firewall perhaps)? After I installed the header on that side, we couldn't find where it went....so we found a spot on the engine to ground it to.
Any thoughts would be great....this is driving me nuts!
Old Jun 26, 2010 | 10:30 AM
lucky131969's Avatar
lucky131969
Originally Posted by WELEPRO
Hey all,
Give me a call.....PM sent.
Old Jun 26, 2010 | 10:31 AM
lucky131969
http://forums.corvetteforum.com/c5-t...e-grounds.html
Old Jun 26, 2010 | 11:36 AM
LuCkYSe7eN11's Avatar
LuCkYSe7eN11
Hey all,
My LG Streets will be here this week. How was the install I was thinking about doing it myself. I did my Corsa Xtreme exhaust 2 days ago with no problems.
Old Jun 26, 2010 | 12:06 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Did you remove the spark-plugs prior to the removal of the old stuff and installation of the headers. Ive see WAY TOO many header installs go wrong due to broken plugs. Carefully inspect your spark-plugs and make sure that they do NOT look like this:
If the spark-plugs check out fine, make sure that the spark-plug wire boots are FULLY seated on the plug and fully seated on the coil towers. The coil ends actually SNAP into place when there properly seated.
Yea, those ground wires are critical. There a 15mm bolt on both sides of the block above and forward of the starter and oil filter housing. The block grounds connect there. The silver braided wire and a black ground wire need to connect to that bolt on the drivers side.
The battery ground and black ground wire connect to the passengers side.
Your in good hands with LUCKY!
BC
Old Jun 26, 2010 | 12:40 PM
WELEPRO's Avatar
WELEPRO
I spoke with Lucky on the phone earlier, and I think we've got it figured out. My O2 sensors are hooked up backwards....I'll switch them tonight when I get home and follow up with the result. The ground wires were installed properly I've discovered.
As far as the installation of the headers, I'll never do it again on any car. I like to think I'm fairly mechanically inclined, but this job was a real PITA. All in, I probably had 16 hours invested in the job, lost a few pints of blood(ok maybe not that many...but my hands are cut to pieces), and I'm sure my neighbors wonder who exactly I was cursing at in my garage all night. It would be a bit easier with a helper.
Old Jun 26, 2010 | 01:03 PM
LuCkYSe7eN11
Thanks for the info... Ive decided I am going to pay the mechanic at our hobby shop on base to do it. I told him I would assist him for no charge (that way I can see if he messes anything up).
Old Jun 26, 2010 | 01:11 PM
Slow Z06's Avatar
Slow Z06
LG's are easy. Try doing some Kooks headders
To Car runs terribly after header install
