I just had this problem, happens when too much water goes in the drainage bungs on the driver side (the wiper motor sits right on top). when too much water gets in, the motor gets soaked, and fries . there's a few threads here on how to bypass the bungs (just cut the openings larger)....I'm waiting for my new motor and assembly to arrive
You might be able to help yourself if you're willing to do some research. Every technical question that's ever been asked/answered can be found in the forum archives. The trick is in the keywords used. Your situation should be simple to find lots of past discussions.
In C5 Tech (it's a technical issue), use search or search this forum (in the red banner).
Use keywords "windshield wiper quit" or similar words. You should find many past threads/replies and some with images of the udders, with suggestions on how to deal with the issue.
