XS Power Headers? Good or Bad?
Old Jul 12, 2010 | 02:33 PM
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
Originally Posted by MDoe8
I bought mine used from another forum member. He had been using them for years but decided to get a new set and hasn't noticed any change except sound which he says is worse now lol.
I really need to get a video of mine. Maybe some time in the next couple weeks.
They really did/do sound good don't they? I think the steel has alot to do with it. The new system is just a touch mellower with a bit of an exotic note to it, just sounds damn good though!
Tim
Old Jul 12, 2010 | 10:10 PM
buckg2's Avatar
buckg2
Love mine. Great fit, easy install, great price. I have 500 miles on mine with the orginal ECS mail order tune. I can't wait to send the PCM back out. It is running a little rich but has not thrown a code.
Old Jul 12, 2010 | 11:10 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The two sets that I installed both ran rich after the istall. Its NOT the headers fault as the header changes the air flow thru the engine (for the better)
My C6 really ran really rich and fuel efficiency went to hell The C5 didn't change too much. C5 Dropped a few MPG and was only rich at WOT.
A good tune will easily milk all the power and economy out of the header install.
Old Jul 13, 2010 | 12:12 AM
Superman09's Avatar
0Superman09
Former Vendor
Definitely! I still get 31 mpg at ~74 mph on the expressway... and I have a big ol' 232/240 lumpy cam
oh yeah, AC on too!
Old Jul 13, 2010 | 01:02 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I drove to and from the last Cruise In (Ct to Bowling Green and back) On the way back,,,I got (fully loaded with two people and a full trunk) 29.3 MPG.
On a most reticent trip Baltimore to Hartwell Ga,,, I got 28.4 and we were playing a LOT!
A properly tuned engine is the ****s! Thank you CHUCK @ Corvettes Of Westchester!!!!!!!! The man makes cars run like they designed to!
Bill Curlee
Old Jul 13, 2010 | 08:46 AM
BoostRetard's Avatar
BoostRetard
I really like mine. Install went well, with no real issues. Fit perfectly. Not loud when keeping it under 300rpm. My wife commented that she thinks it is quieter than the stock headers and H-Pipe in the cabin. I did just trip a code for the rear O@'s last night, but that is common for high flow cats. Will either tune the rear O2's out or turn off the codes for them. I have an EFI live system. Fuel economy seems to be good. My butt-o-meter tells me there is more power there untuned, Looking to do some tweeking once i hook up the wideband. Can't think of any complaints.
Old Jul 13, 2010 | 10:09 AM
Superman09's Avatar
0Superman09
Former Vendor
Old Jul 13, 2010 | 10:41 AM
lucky131969's Avatar
lucky131969
I take it you mean "3000 rpm".........
Old Jul 13, 2010 | 10:48 AM
Superman09's Avatar
0Superman09
Former Vendor
I hope he meant 3000
Old Jul 13, 2010 | 10:52 AM
BoostRetard
I have a really low idle. :P
Old Jul 13, 2010 | 10:54 AM
Superman09's Avatar
0Superman09
Former Vendor
haha, i bet the stock cam even chops down there!
Old Jul 13, 2010 | 11:25 AM
JW Motorsports's Avatar
JW Motorsports
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
I've installed them, but really haven't had time to drive my car.
They went in pretty easy. The passengers side was a little tough, but from what Tim told me I'm the only person that was able to install them from the bottom without jacking the motor or removing the starter (muscle man here lol). I installed them myself on jack stands and another jack to support the mid section of the headers.
The only thing I had a problem with is the passenger side air tube connection. It's a little small and I couldn't get both of the bolts in (I changed mine to the 01+ version).
Old Jul 13, 2010 | 12:47 PM
  #33
Chicago1's Avatar
Chicago1
When do the 1 7/8 version come out?? those are what I'm waiting for
Old Jul 13, 2010 | 06:51 PM
  #34
tstar's Avatar
tstar
Old Jul 13, 2010 | 06:53 PM
  #35
tstar's Avatar
tstar
Yeah you seem to breaking all kinds ground, no one else has had a AIR flange issue either!
You were already tuned for the OBX system weren't you?
Old Jul 14, 2010 | 08:43 PM
  #36
TBH94's Avatar
TBH94
So, do I need a tune with the new exhaust? I wanted to wait until I put the cam in to get a tune. Just pay one time. I won't be putting the cam in until the end of the year. I don't want to ride around with the check engine light on for 6 months.
Is a tune necessary or advised?
Great feedback!
Old Jul 14, 2010 | 08:52 PM
  #37
Darion's Avatar
Darion
Most are going to say necessary. I don't think you "have" to get a tune but you will probably throw codes, gas mpg will suffer as noted above and the full potential of the headers will not be realized, this is what I have read. The codes may only be an issue with catless systems but not sure, someone will chime in on that I'm sure. You could get a mail order tune to get you in the ballpark and then when you do a cam get a full street/dyno tune, just a thought.
Darion
To XS Power Headers? Good or Bad?
Old Jul 14, 2010 | 09:08 PM
  #38
JW Motorsports
Banned Scam/Spammer
Yep.
Finally fixed my squeak which was the ac idler pulley or tensioner(both were worn) so I'll be able to finally test these things out.
Old Jul 14, 2010 | 09:23 PM
  #39
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Great feedback!
You will not HAVE TO get a tune. In other words, your engine will run fine and you will even see a performance gain and you will NOT damage your engine IF you install the headers correctly.
You will however most likely see a slight drop in fuel economy. You will also most likely be some what rich at WOT and being rich, you will not see full HP potential from your header install. It wont hurt the engine as it would if it was a lean issue.
SO,,,,install the headers and when you finish modding, get your tune. I went 9 months with out a tune on my 06 coupe. Man, once your set up is tuned, you will really see the difference..
BC
Old Jul 14, 2010 | 11:07 PM
  #40
Superman09's Avatar
0Superman09
Former Vendor
BC
What Bill said PLUS if you get the catted version and hook up the AIR stuff, you should not throw any codes! My car didn't throw any codes at all with the catted x and only 1 of the AIR fittings hooked up and the other blocked off
