Shifting 2 to 3 issue's
Old Jul 12, 2010 | 09:20 PM
CTD's Avatar
CTD
Default Shifting 2 to 3 issue's
Very frustrating.
When I did the power upgrades the clutch problems showed within a couple hundred miles.
I'm not a drag racer however I do like to shift @ red line with no worries. I wonder if rpm is part of the issue as I do rev much higher than stock, do the big inch lower reving high HP motor's have the same shifting issue's?
The clutch was replaced with the LS7 & new slave with a remote bleeder......might as well do 4:10's @ the same time!
I felt the LS7 clutch would be fine for my style of driving & maintain a near stock like engagement, peddle feel blah blah. I was told the near floor engagement was normal & would improve as the clutch broke in. Yeah maybe, it might be marginally better.
Well right now this sucks, I've searched & the same issues show up over & over again.
So I have place the order for the "Tick", it sounds good & I'm hopeful.
Old Jul 13, 2010 | 10:30 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Did a heads cam install on my 02 ZO6 and 30 min into the on the road tuning run,,, the clutch started to stick to the floor under full power runs! I thought that the clutch was slipping and causing the issue but,,, when I removed the clutch,,,,,it looked new!
It has something to do with the slave cylinder. It looked pretty black and nasty.
I have a brandy new Spec Duel Disk to replace it!
BC
