Starter issue
Old Jul 16, 2010 | 10:33 PM
teongies's Avatar
teongies
Default Starter issue
I have been having an intermittent no start issue and ended up changing the starter. Drove the car for little over a week and the issue came back and stayed this time. I was able to push start the car and get it home.
When I went to check voltages at the TDR relay I was not getting any voltage on the red wire (my understanding is it should be hot all the time). I tried to jumper between the purple and red wire and nothing. I then pulled fuse number 52 (60a) and it was blown. I put a new fuse in and tried to jumper between the Red wire and purple wire and promptly blew fuse 52.
My question is could a bad starter cause the fuse to blow?
Old Jul 17, 2010 | 12:37 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Disconnect the TDR and check the resistance to ground on the PURPLE WIRE.
If its ZERO, check the purple wire on the solenoid ( Remember, it goes thru a fusable link and the wire changes color at the solenoid.
BC
Old Jul 17, 2010 | 09:16 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Follow Bill's advice on this. He knows the starter system backwards and forwards!
Old Jul 17, 2010 | 09:35 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The starter wires are easily baked/fried and damaged by the exhaust system. If your blowing the fuse,,,,,I would start there and look for damage and shorts.
My 98 Coupe had a clogged HVAC drain and it backed up and water got into the TDR and destroyed it. Make sure that the TDR in not damaged.
BC
To Starter issue
