install procedure for rear main seal LS6
Jul 18, 2010 | 04:56 PM
Guys how hard is it to install a rear main seal now that Im doing the clutch? My seal showed moderate signs of spray back all over the back of the block and bellhousing. Do I have to remove that rear engine cover first? I figured I might as well do it since its all apart now.
Jul 18, 2010 | 05:54 PM
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Theres a detailed procedure in the service manual. It states to NOT get any oil on the sealing lip.
Theres also a tool that guides the seal onto the crank to keep the lip from getting flipped around.
Its doable and you do not need to remove the rear cover.
BC
Jul 18, 2010 | 06:07 PM
I dont have service manuals unfortunately. Where does one get this tool from? Can anyone send me a pdf of the pages on the "how to" of it please!
Jul 18, 2010 | 07:29 PM
St. Jude Donor '15-'16-'17-'18
The manuals are $150 from GMPartsHouse. You have no idea how valuable they are to have. Definitely worth there weight in gold..
EDIT:
http://www.ls1tech.com/forums/genera...main-seal.html
Look at post 3
Jul 18, 2010 | 08:42 PM
CI 6,7,8,9,11 Vet
St. Jude Donor '08
PM me your E Mail address and I wil send it to you.
BC
Jul 18, 2010 | 09:09 PM
Quote:
Originally Posted by
Bill Curlee
BC
PM sent.
Jul 18, 2010 | 10:01 PM
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Jul 18, 2010 | 11:02 PM
St. Jude Donor '06-'07-'08-'09
you might want to find one of the Kent Moore LS1 kits. You can find them on the auction site.
search: KENT MOORE J-43145
just make sure the kit is complete
Jul 18, 2010 | 11:27 PM
CI 6,7,8,9,11 Vet
St. Jude Donor '08
printmanjackson
I found a Kent Moore Gtrag Differential Shim Selection tool ($400 dollars NEW) for $29.97. I better restate that,, "MY WIFE FOUND IT!"
Shes a KEEPER!
E-bay can be good.
BC
Jul 18, 2010 | 11:39 PM
I found GMPP # 12614813 available online at a popular vendor. Its the rear engine cover with new bolts, cover gasket and INSTALLED rear main seal on the cover. Eliminates the expensive and hard to get J tool. $ 30 bucks.
2001 ,
2005 ,
c5 ,
c6 ,
corvette ,
cover ,
howto ,
install ,
ls1 ,
main ,
rear ,
replacement ,
replacing ,
seal ,
tool
