Window Valet Programming
Old Jul 18, 2010 | 09:51 PM
sfc711's Avatar
sfc711
Default Window Valet Programming
Can someone please explain in simple terms( I am an idiot) how to program the window valet to raise and lower the windows. I followed the directions by pressing the reset betton and the door unlock at the same time and the gauge needles moved and chime sounded but nothing showed on the DIC. If I have codes do they need to be cleared first. I just installed new tires and TPMS and I keep having low tire pressure readings on one tire but it is filled up to specs. Thanks,Gary
Old Jul 18, 2010 | 10:07 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
Instructions attached
Key off, correct?
You should not attempt to access
the Configuration Mode unless the key is absent from
the ignition, or in the OFF position. Once in
Configuration Mode, the following features can be
directly accessed…
After the sweep the tach should show 1K
For example, to configure the remote power window
option, follow through the Configuration Menu
Structure. The top level has four options:
1-Panic! Mode
2-Display high speed
3-Activate accessory power
4-Enter configuration menu
You'll press '4' on the DIC to enter the configuration
menu.
Under the '4' option, there's four more items:
1 - configure windows
2 - configure door locks
3 - configure accessory power
4 - restore factory defaults
You'll press '1' on the DIC to access the window
configuration options.
Under the '1' options, there's four more items:
1 - disable
2 - enable and calibrate
3 - window up strength, normal
4 - window up strength, strong
You'll press '2' on the DIC to enable and calibrate the
windows. This option requires a pin number. The last
paragraph of the disclaimer describes the relationship
between the PIN number and the serial number. The
serial number is on the disclaimer page and on the unit.
Please be sure you've read the disclaimer.
File Type: pdf
Old Sep 21, 2013 | 11:43 AM
NOLAVette's Avatar
NOLAVette
Default Step by step to set window-up strength to "Strong"
I finally figured it out. Nevermind.
I've read and re-read the cryptic instructions for the window valet I just bought and I cannot figure out the sequence for setting the window-up strength to the "Strong" setting. The windows instantly drop back down as soon as I put them up using the valet.
Can someone provide the steps to do this?
Thanks,
NolaVette
To Window Valet Programming
