Fuel Filter DIY Change
Old Jul 18, 2010 | 10:32 PM
FASST LN's Avatar
FASST LN
Default Fuel Filter DIY Change
I have reason to believe that my fuel filter (never been changed with 87k miles on the odo) might be the cause of my high rpm WOT hesitation.
I launched into changing it today (replacement NAPA part). I managed to get the two rear lines off pretty easily and enjoyed the gasoline shower. I have the 3/8 inch disconnect tool (the cheap one that is round and simply pops around the fuel line). I tested it on the new fuel filter and it slipped in no problem.
After working on the existing filter for about 2 hours, I still haven't gotten it free. I had my electric cutouts in place making access difficult, so I finally removed one to give me more space. However, I still can't get the disconnect tool to seat all the way down onto the filter. It goes about 80% of the way and it feels like it snaps in but when I let go it eases back out.
I've been squeezing the tool towards the filter while at the same time pushing the filter towards the fuel line (towards the front of the car) but I can't get this dang thing OFF!!
My forearms are pretty mangled and I'm defeated.
Any suggestions?
Old Jul 18, 2010 | 10:52 PM
die hppy's Avatar
die hppy
Damn sounds like my day,somebody jump in and help out.
GL
Old Jul 19, 2010 | 12:37 AM
RX-Ben's Avatar
RX-Ben
try a different tool. One of the cheap plastic ones I bought works, the other doesn't. Not sure if the $ aluminum ones are any more consistent, though I was told by Advance that the plastic ones work best.
Old Jul 19, 2010 | 12:43 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Second fuel filter post today.
PUSH the fuel line INTO the filter and then insert the tool. Pushing it in, releases the pressure off the retaining spring and makes tool insertion easier and more effective.
BC
Old Jul 19, 2010 | 03:29 AM
stryderss's Avatar
stryderss
and taadaaa!!!! Im doing the same thing. do like bill said and it will be of in a snap.
Old Jul 19, 2010 | 09:07 AM
FASST LN's Avatar
FASST LN
Can't wait to get home and try that tonight.
143 times: Number of occasions Bill C. has saved my tail!
Thanks guys!!
Old Jul 19, 2010 | 08:42 PM
FASST LN's Avatar
FASST LN
This is still not working.
I'm about ready to cut it off with my hacksaw. How deep does the fuel line go into the filter?
Does it go deeper than the little nozzle that comes off the filter (the part that I can't get to release)?
Old Jul 19, 2010 | 08:45 PM
jaybar's Avatar
jaybar
Thanks guys!!
FASST LN, I am going through the same thing as you. I started on Saturday and am still stumped.
Check out this thread where people have given me some good suggustions.
http://forums.corvetteforum.com/c5-t...#post157474919
Good luck to both of us and thanks to all the forum members how have
helped.
Jay B
Old Jul 19, 2010 | 09:09 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Try twisting the filter on the line and see if it will break loose from the O ring. While your twisting it, also try inserting the tool and pushing the line into the filter to release the spring
BC
Old Jul 19, 2010 | 09:30 PM
FASST LN's Avatar
FASST LN
Where's my blowtorch!?
j/k
Old Jul 19, 2010 | 10:03 PM
FASST LN's Avatar
FASST LN
I have been pushing the filter towards the engine while trying to insert the disconnect tool into the filter. At the same time I've rotated the filter and the disconnect tool counter to one another. I've sprayed lithium grease into the filter end trying to lube the disconnect tool. I've inserted my small flathead screwdrivers into the filter trying to move/pry the springs a bit.
I've now detached the fuel line from its bracket to get more clearance but it still won't budge.
I really think the only option is to cut this thing off, but I don't know how far the fuel line runs into the filter.
Old Jul 19, 2010 | 10:06 PM
FASST LN's Avatar
FASST LN
I'm wondering if one of the scissor type tools might be better because you could insert it as far as it would go and then open the scissor, expanding the tabs?
Old Jul 19, 2010 | 10:55 PM
00Corvette's Avatar
00Corvette
That's the type that I use, along with them being the aluminum pair and I haven't had an issue yet. I've had the intake off 10 times or more etc and no issues.
Keep at it using the pushing on fuel line and twisting the filter...that spring isn't too strong and you should be able to break it out of there before having to cut the line..I actually did it before I knew about the special fuel line tool on these cars...LOL.
I used a flat head screw driver(small) and just pried around until the little spring broke..
Old Jul 22, 2010 | 08:49 PM
FASST LN's Avatar
FASST LN
Still couldn't get the thing off. Finally had to use needle nose pliers and some spreading tool to tear up the lip badly enough to pull the clips up. Once I pulled back on one clip, the filter fell off, leaving just the clip clinging to the fuel line.
Old Jul 22, 2010 | 09:00 PM
FASST LN's Avatar
FASST LN
But I got my revenge:
To Fuel Filter DIY Change
