Bad Gas Mileage
I used to get about 30mpg highway and 17-18mpg city average.
It has just kept dropping over the past 2 years and I am down to 11-12mpg city average?
• New tires 32-psi
• New Iridium Plugs Red Gm Performance wires
• New Air Filter
• Spray cleaned MAF and Throttle body.
• No codes
• Mobile 1 oil changed every 6 months
• Use only Chevron w/Techron Premium fuel
Car seems to idle/run fine and I drive it relatively mild, so what else might cause this mpg drop? I did get a mail order tune last December and dropped about 1-2 mpg in town, but was experiencing the loss prior to the PCM retune.
Any ideas what might be causing this radical drop over time? Even after getting a new Long Block (under warranty), mpg continued to drop?
During warm up and WOT the PCM operates in OPEN LOOP and the AFR is controlled by various preset tables.
Using aftermarket data logging equipment, you should read the O2 sensors and see if there properly functioning. They cycle high to low, low to high, high to low...100ma to 900ma.......... to control the overall average AFR. If the O2 sensor values ar hanging out at one value there NOT functioning and that would cause poor fuel efficienct issues.
You also need to read your Long Term Fuel Trims (LTFT) they are the indicators as to what the PCM is doing to maintain that 14.7:1 closed loop AFR. The PCM can only correct +/- 25%. If the LTFT is significantly off, it is an indication that something is wrong that is causing a rich or lean condition that the PCM needs to correct.
- How are you reading the DTCs???
- Are you using the built in DTC routine?
- Are you reading the DTCs before you shut down the engine??
Some common things that effect Engine efficiency are:
- Dirty MAF
- Defective O2 sensors and or wiring
- Dirty Air Filter
- Vacuum leaks
- Poor tune up (you already addressed that issue)
- Some other engine sensor not functioning correctly (normally seen with a CEL)
Hope this helps.
BC
- Dirty MAF
- Dirty Air Filter
- Vacuum leaks
Hope this helps.
BC
When I had on oiled up MAF sensor, I would get a huge hesitation at 4500rpm WOT.
When I cleaned it with cleaner the hesitation cleared up at WOT.
Sorry to thread jack.
PM me if you can.
- Dirty MAF
- Dirty Air Filter
- Vacuum leaks
Hope this helps.
BC
Can the O2 sensors be bad and still not throw a code?
Only way to real check is with a tuner.
You can do what I did for my C6. Its a CAN Buss system but the Aftermarket Scanner that I purchased (ACTRON CP9180) can data log a C5 or C6 and it was only $130.
I'm from the "other" Forum...C-4. Thats almost the stock answer over there.
