Steering rack instalation/removal
Old Jul 27, 2010 | 11:30 PM
m6 c5's Avatar
m6 c5
Default Steering rack instalation/removal
How easy/hard is it to replace the rack?
And are there any tips that would make it easier?
Oh and I do have a shop manual.
Old Jul 28, 2010 | 12:18 AM
kp1's Avatar
kp1
It isn't hard. There are some good DIY threads on removing the rack.
Old Jul 28, 2010 | 01:32 AM
00Corvette's Avatar
00Corvette
Do a search using Bill Curlees name on swapping a harmonic balancer or steering rack. It may be about a cam swap but I'm pretty sure it was the balancer.
Anyway, the rack isn't very difficult to pull off. It's a very straightforward job.
Old Jul 28, 2010 | 09:12 AM
m6 c5's Avatar
m6 c5
Yea I did several searches and didnt come up with anything.
So being that its not that hard will it only take me a few hours or an entire day?
Old Jul 28, 2010 | 09:24 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
It's not all that difficult. You will need a set of flair nut wrenches for the hydraulic lines. You only need to remove the two main ones on the top of the hydraulic housing.
Dont loose the rubber bushings or steel bushing that mounts the rack on the passengers side.
DONT force the aluminum tabs the the bushing mounts in. They break easily if bent.
Some people have to loosen the K member bolts to completly remove the rack. I did NOT on my 02 ZO6.
BC
Old Jul 28, 2010 | 09:36 AM
Mark C5's Avatar
Mark C5
St. Jude Donor '08-'09-'10
I would recommend that you use crows foot wrenches in place of flare nut wrenches for the lines.
Also, when you start the rack back into the mounting ears on the passenger side, the rubber bushing has a tendency to fold over on it's self. You need to reach behind the rack and make sure the bushing is starting in the ear before you put much force on it.
Old Jul 28, 2010 | 01:10 PM
corvettebob1's Avatar
corvettebob1
I spray the rubber bushings with silcone spray before reinstalling and it will eliminate this problem.
Old Jul 28, 2010 | 02:32 PM
Blow Torch's Avatar
Blow Torch
I'm the wet rag here, but it was an AWFUL job for me (by myself), and I've done almost every mod you can do to one of these cars. I got it out easy enough, but when I tried to get it back in, I needed to be in two places at the same time
Expect the worse and hope for the best and you should be ok.
Old Jul 28, 2010 | 03:08 PM
byronhunter's Avatar
byronhunter
Don't let the steering Wheel turn while it's out.
It's Important!
Old Jul 28, 2010 | 03:59 PM
KrispyZ06's Avatar
KrispyZ06
It's Important!
For AH/TC among other things...
Old Jul 28, 2010 | 07:54 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
It's because of air bags clock spring and Steering sensor.
Old Jul 28, 2010 | 09:01 PM
m6 c5's Avatar
m6 c5
Well im planning on setting aside an entire day and putting it in the fornt of the garage incase i dont get it done so I can get the other cars out. Pluss Im sure that if I need it I can get some one to help me out.
Also I assume that I have to keep the wheels from turning along with the steering wheel.
Anyone have any sugestions on how to keep them from turning or do I just need to be extra careful?
Old Jul 28, 2010 | 09:27 PM
00Corvette's Avatar
00Corvette
post up if you need any help man.
you got the right idea just taking a day and devoting it to the job. it'll probably go quicker if you don't put yourself on a time table...
on the steering wheel...i was just very careful not to bump the wheels/steering wheel. It'll take a little effort to turn even with the front end off the ground so as long as you don't kick the wheel or something while you're messing w/ the rack..you'll be fine..
wait for a response from Bill or AIG as they may have some better advice for a way to hold the steering wheel(there's a tool that we had at the place I was working at the time I had mine off) it's a tool that's used for alignments but I wouldn't buy one unless you plan on doing this stuff often(waste of 30-40 bucks imo) i'd rather buy the flair nut wrenches if I was looking for an excuse to buy a tool..lol
Old Jul 28, 2010 | 09:30 PM
Hi/Tek/Vette's Avatar
Hi/Tek/Vette
Your car looks mean ....
got any better pix ..??
Old Jul 28, 2010 | 09:39 PM
PewtVette's Avatar
PewtVette
More like a puzzle than anything- especially the first time you do it. I had the oposite experience- I had help getting it out but put it back in myself (after I bungeed everything out of the way). I didn't loosen the K member bolts either.
Old Jul 28, 2010 | 09:47 PM
m6 c5's Avatar
m6 c5
Is there anything else I need to remove to get the rack out of the car. I didnt really look when I was under there, I was just escited it wasnt comming from the block.
Old Jul 28, 2010 | 10:32 PM
01vetter's Avatar
01vetter
The brake ABS unit is attached to the rack. You have to unbolt it, take off the bracket and raise the unit. I tied mine up to the alternator.
If you have a manual, I suggest that you read it. I think that you have to lower the front cross member to get it out. The manual will tell you by how much.
The hydraulic lines are a PITA! Mine were way over tightened by GM.
To Steering rack instalation/removal
Old Jul 28, 2010 | 10:56 PM
m6 c5's Avatar
m6 c5
Yea im sure everything is going to be hard to get off. I cant get very many things off the car because they are soo tight like the demon key, rear brake caliper mounting bracket and the front lowering bolts will not budge, I busted a wrench trying to turn them.
Old Jul 28, 2010 | 11:40 PM
00Corvette's Avatar
00Corvette
soak those bolts in some PB or the like...the lowering ones.
calipers...pull harder or get some more leverage. those bolts can handle it, just don't round it off and make sure you have the right size weapon
00Corvette's Avatar
00Corvette
what's the demon key? lol
