Rotating Crankshaft by Hand?
Old Jul 31, 2010 | 07:05 PM
geezel's Avatar
geezel
Default Rotating Crankshaft by Hand?
What's the best way to rotate the crank by hand in small increments? I suspect it's making a tool to fit over the crank bolt. (Sawed-off socket welded to a piece of flat bar?). Does anyone sell a ready made tool for this?
Old Jul 31, 2010 | 07:52 PM
99blancoss's Avatar
099blancoss
Former Vendor
St. Jude Donor '10-'11-'12
socket and 1/2 breaker bar work fine
Old Jul 31, 2010 | 08:13 PM
geezel's Avatar
geezel
I've got about 7/8" between the head of the crank bolt and the steering gear housing. No room for a standard socket / breaker bar there... Thus the comment about the sawed-off socket and flat bar. The 12 point ARP crank bolt is 15/16", correct?
Old Jul 31, 2010 | 08:51 PM
99blancoss's Avatar
099blancoss
Former Vendor
I'd have to go check but I think it was 27mm? I could be way off..LOL
Old Jul 31, 2010 | 08:56 PM
PewtVette's Avatar
PewtVette
Having more money than time, I simply ran down to AutoZone and bought one of their 1 1/16 12 point wrenches. Fits in there just fine:
Old Jul 31, 2010 | 09:23 PM
geezel's Avatar
geezel
Thanks but an open end wrench won't work on the 12 point ARP crank bolt.
Old Jul 31, 2010 | 09:30 PM
PewtVette's Avatar
PewtVette
??? I'm confused. Why not use the closed end of the wrench? I did- it fits perfect.
Old Jul 31, 2010 | 09:50 PM
bumble-z's Avatar
bumble-z
Couldn' you pull the plugs, then turn by using pully/belt by hand?
Old Jul 31, 2010 | 09:56 PM
vettenuts's Avatar
vettenuts
I made a tool by splitting a socket and welding it to a flat bar. I like this idea though and will pick one up now that I know it will fit
Old Jul 31, 2010 | 10:10 PM
geezel's Avatar
geezel
You're right. My mistake
Couldn't you pull the plugs, then turn by using pully/belt by hand?
That might work.. I was hoping to come up with something the didn't require pulling ALL the plugs each time. None of the accessory pulleys have nuts that will turn the pully though???
To Rotating Crankshaft by Hand?
