Cold Air Intake???
Old Aug 2, 2010 | 08:55 PM
lsutherland's Avatar
lsutherland
2nd Gear
Default Cold Air Intake???
There was a thread on here about a year ago that showed where the Cold Air Intake valve is located. It causes the codes to set off a reading that is the same as the O2's being bad. The recommendations were to spray a cleaner (I think it was a carb cleaner) into that valve to keep it from sticking. Can anyone help?
Thanks!
Old Aug 2, 2010 | 11:28 PM
Dave68's Avatar
Dave68
I recommend doing a search for smog pump check valve. Remember, though that resetting an error code may give you a false sense of having fixed the reason for the code. Another thing to thnk about is that petroleum products that make their way into catalytic converters may shorten their lives. Cats don't take kindly to oil and unburned fuel.
