Accusump Question
Old Aug 16, 2010 | 12:20 PM
marco383's Avatar
marco383
Default Accusump Question
What is the recommended protocol for draining and refilling oil in an Accusump-equipped C5? I'm assuming that before draining, I should run a few miles with the Accusump valve open to warm all the oil, but then?
Old Aug 16, 2010 | 01:16 PM
waddisme's Avatar
waddisme
Post this question in the Road Racing section. Most of those guys have one so they will know. I have one, but don't have it installed yet, but soon. Good luck.
Old Aug 16, 2010 | 01:36 PM
AU N EGL's Avatar
AU N EGL
You can drive around a bit to warm up the oil.
Hint, measure how much oil comes out. Not all will drain and that is OK. My engine, accu-sump, oil cooler and oil lines holds 10 1/2 qts. but only 9 qts to 9 1/4 drain out.
When filling back up put in 7 quarts,
start engine and let idle,
add another quart.
add as needed to get to YOUR full level.
To Accusump Question
