HELP!!! engine dies when turn off hazard switch
Old Aug 17, 2010 | 10:19 PM
blkdevl's Avatar
blkdevl
Default HELP!!! engine dies when turn off hazard switch
car died today.lights were goin haywire. hit the breakes dash and radio loghts dim. taillights dont work figured out bye chance that if i had the hazard switch pushed in the car would start when i turn it off the car dies.when i lock the doors with the remote the horn starts goin off and on.. have no clue besides a bad ground somewhere..
if anyone has had this happen to them or ideas would be nice to know
Old Aug 17, 2010 | 10:50 PM
whitehooptie's Avatar
whitehooptie
You sir have a ground issue. I think I read on here somewhere that there are 2 ground wires under the hood towards the nose that breaks or corrodes. I think it is under the electrical sticky
Old Aug 18, 2010 | 12:52 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You most likely have a WET BCM or a Class II Serial Data Buss issue.
BCM controls all that stuff.
Its easy to check the BCM and passengers foot well for water/dampness. MAKE SURE, that you check to see if the carpet insulation under the seat is damp cause thats where any water in the foot well ends up.
BC
Old Aug 20, 2010 | 12:17 PM
blkdevl's Avatar
blkdevl
thanks i checked it out. no dampness.. i was takin it to the shop and hit another bump and started working fine again...grrrrrr
To HELP!!! engine dies when turn off hazard switch
