Electronic dash noises
Old Aug 18, 2010 | 04:52 AM
mcviooue's Avatar
mcviooue
mcviooue
Default Electronic dash noises
Hi!
I hear some bad noise coming from my 2000 conv dash... Sounds like bad conection or something. Having clean the grounds connectors have solved most of my electronic problmes excepts that one. Please help.
mcviooue
Old Aug 18, 2010 | 11:46 AM
Nver2loud's Avatar
Nver2loud
Does it sound like its coming from the "dinger" that dings when you start the car? If so, im having the same problem and as soon as i get some time im going to dig into it further, for the time being, i disconnected the speaker behind the cluster.
Old Aug 18, 2010 | 11:58 AM
mcviooue's Avatar
mcviooue
mcviooue
Default tic tic tic
Thanks for the answer. I think we have the same problem. It sounds louder when I open the door and start the car. After the sound stays softer but repetedly. It's like a tic, tic, tic, etc.
Can you tell me how to disconnect the speaker behind the cluster? I'll let you know if my mecanician find something.
Mic
Old Aug 18, 2010 | 12:05 PM
stormrider's Avatar
stormrider
Use these instructions for removing the gauge cluster: http://www.vetteessentials.com/instr...zel_howto.html then remove the power pack from the back of the clusters and the screws that hold the back panel and you will see the connection to the speaker.
Old Aug 18, 2010 | 12:23 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Heres a post that explains IPS disassembly.
- C5 Gage Cluster disassembly - http://forums.corvetteforum.com/c5-t...post1570380674
NOTE! HVAC damper actuators can make weird noises when they calibrate or attempt to adjust the damper doors. You can pull the HVAC fuse and disable the actuators and try to eliminate that as a possibility of being the noise.
BC
Old Aug 18, 2010 | 12:32 PM
mcviooue's Avatar
mcviooue
mcviooue
BC
Thanks Bill, I'll try to find the # of the HVAC fuse.
Mic
Old Aug 18, 2010 | 02:18 PM
Nver2loud's Avatar
Nver2loud
Hopefully this weekend I will get time to try to find an answer for my noises, if the blend doors arent your problem, get in touch with me and ill fill you in where I am so far with mine
To Electronic dash noises
