WOT popping - help!
my thoughts on possible causes:
-needs retuned?
-bad coil pack (will check tonight)
-fuel pump not keeping up (can i even check this without a wideband?)
-excessive carbon buildup (i use techron about once a month. should i try seafoam?)
the car has 127k miles. mods are listed in my profile. rev limiter is set to 6500. can anybody think of any additional causes or things i may want to try? is it bad on the engine to keep running like this?
Thanks,
Dan
1st try seafoaming before doing anything else you have high milage and a tune cant compete with carbon build up.
2nd get a fuel pressure gauge and drive around "spiritedly" if the pressure drops more than about 5-8psi you might to upgrade the fuel pump.
So far you are on the right track
Hot air is LESS dense (thinner) needs LESS fuel to keep the same AFR
The commanded AFR for WOT in the Tune remains the same regardless of weather--Say it's set at 12.5 ------ In the winter it may be leaner or just perfect and in the summer it's rich--Tha's why tuners always allow for weather changes while tuning WOT AFR's and will error on the side of rich --a tad--
The ECM corrects the AFR via it's fuel trims but only during P/T opeation and NOT at WOT
My guess is plugs and wires--- mostly the wires---Aftermarket wires tend to be thicker and harder to get them onto the coil---make sure you hear them "snap" when putting them on---air gets trapped in the plug boot and won't escape when installing so the air pressure will sometimes pop the coil end off--- try using some dielectric grease and i will stick like a thin wire tie (zip tie) into the coil boot when installing them--this allows a path for the air to escape--snap them on and then pull the tie out---
