Transmission service
Old Aug 29, 2010 | 05:15 PM
thaitime's Avatar
thaitime
Default Transmission service
Can someone give me a link with step by step instruction on how to change fluid and filter on a 1999 C5 A4 coupe
thanks in advance
Old Aug 29, 2010 | 05:27 PM
00Corvette's Avatar
00Corvette
thanks in advance
I don't know of a link for this.
you have to be able to get the car up on a lift or jacks...completely level and running in park/neutral/drive
Then you have to have some type of fluid transfer pump so you can pump the fluid up into the transmission fill hole till it spills out.
This is all there is to it. The pan just drops and the filter should be right underneath.
If you don't have a good fluid transfer pump..I don't know how to do it.
Old Aug 29, 2010 | 05:40 PM
robsc501's Avatar
robsc501
Hi There,
This should help you.
www.idavette.net/hib/c5diy/c5diy2.htm
robsc501
Old Aug 29, 2010 | 10:01 PM
thaitime's Avatar
thaitime
Thanks guy's this is good info I will bookmark it.
To Transmission service
