Shifter Changeover C5 to C6
Old Sep 3, 2010 | 05:26 PM
66redster's Avatar
66redster
Default Shifter Changeover C5 to C6
To change over a C5 shifter to a C6 shifter GM Parts House (Gene Culley) sells a C6 shifter Kit, which includes shifter,shift ****, and bolt,no boot.
Do i require bolts,washers,gaskets or any other parts for the change over?
Old Sep 3, 2010 | 05:35 PM
jirasvet's Avatar
jirasvet
i did not.
Old Sep 3, 2010 | 05:46 PM
Mark C5's Avatar
Mark C5
St. Jude Donor '08-'09-'10
Not unless you lose some.
Old Sep 3, 2010 | 06:00 PM
lucky131969's Avatar
lucky131969
Nope. You're golden....it's a quick swap...
Old Sep 3, 2010 | 08:00 PM
vettenuts's Avatar
vettenuts
One tip, at least what I did. Turn the boot inside out and carefully remove the glue at the top of the boot. Push the new know into the boot and get an o-ring that will snap the boot into the groove of the ****. Then once the shifter is in, slide the **** into the shifter, install the screw and turn the boot right side out and snap back into the console. I did three this way and it seemed to work great.
I like this shifter much better then stock and the aftermarket I tried
Old Sep 3, 2010 | 08:09 PM
Joy of 6's Avatar
Joy of 6
Takes the slop out of the shifts,
To Shifter Changeover C5 to C6
