Looking for the Math on headers
Old Sep 6, 2010 | 11:03 PM
TheRadioFlyer's Avatar
TheRadioFlyer
Supporting Vendor
Default Looking for the Math on headers
I understand the concept of how headers are superior to traditional cast iron manifolds, but i'm looking for the math behind them, particularly how primary length and diamater affect various parts of the torque curve.
Any reccomended reading?
in case you're wondering, I'm considering moving from my frankenstein setup to a LG/Borla setup.
Old Sep 6, 2010 | 11:07 PM
lucky131969's Avatar
lucky131969
No offense, but have you tried doing a google search. There are tons of articles about headers. Here's one of many...:
http://www.superchevy.com/technical/...der/index.html
Old Sep 6, 2010 | 11:27 PM
zeevette's Avatar
zeevette
Why the need for pseudo science, when you can just choose from one of the top brands that're constantly talked about here. Go with LG Pros, NOT Superpros, which are also sold at Wally World, or so I've heard. Those guys @ LG have been very good to me regarding service, as well as quality.
Old Sep 6, 2010 | 11:50 PM
TheRadioFlyer
Supporting Vendor
Most articles (like this one) explain the basic concept with a few numbers. focusing on primary length and assuming there are equal length primaries, there should be a "sweet spot" in the RPM band that can be calculated based on pulse harmonics
Old Sep 7, 2010 | 12:00 AM
Domin8r's Avatar
Domin8r
Just so you know, the LG pro's made by Borla are no longer for sale by LG (discontinued) and now only sells the streets or super pro's, which are made......overseas
Old Sep 7, 2010 | 05:18 AM
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
Generally primary lengths are governed by the application, longer primaries for low end and shorter (mid lengths) for high end power. To truely get a set of Headers for YOUR car as every engine is different and they need to be custom built with a specific application in mind and that just isn't feasable or cost effective on a street car...
I don't think harmonics play a large role or as large a role as pulse velocity and scavagening, except at the collector. Reversion at the heads is also a troublesome nuance but with most well designed systems that isn't an issue.
FYI Equal primary length isn't nearly as critical as people make it out to be. They can actually range as much as eight inches in difference without any detrement.
I think your ever curious mind is getting you in alot deeper then you to dig for a street car!
Old Sep 7, 2010 | 05:24 AM
vettenuts's Avatar
vettenuts
Here is an article on Jack Burns and Tri-Y headers. Link
The LS1 really likes the Tri-Y arrangement (note that the cast manifold from GM that came stock was also a Tri-Y arrangement).
Old Sep 7, 2010 | 07:06 AM
TheRadioFlyer
Supporting Vendor
I was going LG for headers, cats and X-pipe and Borla stinger for the mufflers.
Old Sep 7, 2010 | 07:32 AM
AU N EGL's Avatar
AU N EGL
That is the constant debate on many forums.
Think it may also depend on which 'sweet' spot you want? the low to mid range torque curve sweet spot, or the higher rpm HP curve sweet spot.
Exhaust harmonics are a closely guarded secret
Old Sep 7, 2010 | 08:37 AM
LuCkYSe7eN11's Avatar
LuCkYSe7eN11
You will love the LG's. I have mine installed with the x-pipe, cats, and corsa xtreme exhaust. I have the street LG's and didnt have any problems with the install the headers went right in.
Old Sep 7, 2010 | 09:29 AM
wca_tim's Avatar
wca_tim
The real math is heady stuff - even for someone with a phd in chemical engineering. to even come close to modeling all of the variables - in cluding flow characteristics as a function of pressure and temperature for everything from the intake to the tail pipe would be a daunting undertaking. there is a lot of "art", in this area and some general rules of thumb that apply in specific situations, BUT as mentionde above, this information was hard won and is not somethjing shared openly in a detailed fashion. I would think that tech folks from the company you're looking at buying headers from can explain some of the most important aspects in the context of their own header designs. maybe give them a try?
Old Sep 7, 2010 | 09:31 AM
TheRadioFlyer
Supporting Vendor
I'm looking to get the sweet spot as close to 2000rpm as possible. My SC picks up around 2500-3000RPM. Before my SC install, my SSAC headers picked up around 3500 rpm. Right now i have a lull between idle and 2500 rpm. I'm hoping LG headers will help take up the slack in the lower part of the powerband.
Old Sep 7, 2010 | 09:51 AM
AU N EGL's Avatar
AU N EGL
LGs will fill that 2000 to 3500 void. Second choice would be ARH. both are very close.
IIRC the Longer primary's and move the x-pipe as far back as possible provides much more low end torque. for thet Get up and gone, SOTP acceleration .
Old Sep 7, 2010 | 11:02 AM
lucky131969
If you have belt driven SC, that is the nature of the beast. You'll never get that off idle hit..........like on a maggie, kenne bell, etc.
Old Sep 7, 2010 | 12:51 PM
vettenuts's Avatar
vettenuts
Take a close look at the Tri-Y design.
To Looking for the Math on headers
