AC Manifold gauges help?
Old Sep 8, 2010 | 09:30 PM
dmarkshark's Avatar
dmarkshark
Default AC Manifold gauges help?
I went out and purchased an AC maniflod gauge from HF. Thought I would check my AC since it stopped working, went to put it on but the connections are the wrong size? Do I need an adaptor, or different hoses, or what?
Old Sep 9, 2010 | 07:44 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
You'll need a gauge set for R134 systems. R12 will not work. Take them back.
Old Sep 9, 2010 | 07:52 AM
dmarkshark's Avatar
dmarkshark
I did get the R134 set, anyway thats what it says on the box and the manuel.
Old Sep 9, 2010 | 08:38 AM
rebelheart's Avatar
rebelheart
There are two different sizes to the connectors,are you sure you are putting them on the proper ports?
Old Sep 9, 2010 | 09:09 AM
Etz's Avatar
Etz
If its from harbor freight, you never know what you may get. I was in there one day and a guy was retuning a clock that was running backward. He tried several of them and the all ran backward... Some stuff OK, some junk..
Old Sep 9, 2010 | 09:17 AM
SaberD's Avatar
SaberD
i bought mine from harbor freight and it worked just fine. i suspect you are plugging them into the wrong place.
Old Sep 9, 2010 | 09:52 AM
Pie R Squared's Avatar
Pie R Squared
I got a set of the Harbor Freight gauges and a vaccum pump, everything worked fine.
Old Sep 9, 2010 | 10:33 AM
dmarkshark's Avatar
dmarkshark
MMMM? I'll have to take another look tonight. I am sure I had the High and Low side correct, even tried the other way just to see with no luck. I had the red for the H and blue for the L as indicated, with the H side on the car by the sensor and L back by the dryer. It seemed like the H side was larger than my connection, and the screw threads were futher down, is it possible I need some type on a quick release connection instead. I know when I had my AC worked on ,the guy had a quick release connector that he just slid on. I think the L side connection was ok, I didn't put it on as I was stuck with the H side issue.
Thanks for all of the help, and I'll try again tonight.
Old Sep 9, 2010 | 11:45 AM
dougbfresh's Avatar
dougbfresh
Most 134A systems have quick disconnects of DIFFERENT sized so people don't try to recharge their systems from that little can and plug it into the high side by accident.
Old Sep 9, 2010 | 01:20 PM
dmarkshark's Avatar
dmarkshark
I thought when I looked at my lines last night, (red and Blue) they both looked the same. And they probably were as I could hook up either end of both hoses to the gauge connections. IF they were correct, would there not be one connector (R)that was too big for the gauge? Is so, I have a bad R line.
Old Sep 9, 2010 | 01:22 PM
lucky131969's Avatar
lucky131969
I thought when I looked at my lines last night, (red and Blue) they both looked the same. And they probably were as I could hook up either end of the hose to the manifold connections. IF they were correct, would there not be one connector that was too big for the manifold? Is so, I have a bad R line.
What manifold?
Old Sep 9, 2010 | 01:23 PM
dmarkshark's Avatar
dmarkshark
The gauges. Sorry,corrected it.
Old Sep 9, 2010 | 01:26 PM
lucky131969
The gauges, sorry.
Can you just post a pic of the hose ends?
Old Sep 9, 2010 | 01:31 PM
dmarkshark's Avatar
dmarkshark
Probably not, not that far along on the know how on this forum. But, I will try with my IPhone later on when I get home.
Old Sep 9, 2010 | 02:30 PM
00Corvette's Avatar
00Corvette
try a search on "how to post pictures"
http://forums.corvetteforum.com/help...es-thread.html
Old Sep 9, 2010 | 04:59 PM
dmarkshark's Avatar
dmarkshark
Ok, I got it figured out. The short manuel it came with wasn't very clear on directions, went to the HF and downloaded (did not know I could do that)a better manuel and now see what I was doing wrong.Things aren't always the way they look like they should be. I feel like an idiot,but learned something new. Sorry for waisting everyones time, but I appreciate the help. I also now know how to do the pictures so thanks for that as well. Thanks all, appreciate the help.
Old Sep 9, 2010 | 05:08 PM
Hi/Tek/Vette's Avatar
Hi/Tek/Vette
did Your Gauge Set also come with Safety Glasses ..???
To AC Manifold gauges help?
Old Sep 9, 2010 | 06:16 PM
dmarkshark's Avatar
dmarkshark
no, BUT it had directions on how to use them, but again they weren't very clear either, so I'll have to check on that as well.
Old Sep 10, 2010 | 09:37 PM
bighank's Avatar
bighank
Default Have same HF guages one fitting is very tight
When looking for adapters to my old (35 years) guage set found it was cheaper to buy the whole set from HF. When you connect the hoses to the guages make sure you put the blue or low side hose on the guage reading vacuum and pressure. The guage fittings are the same but the connectors are different sizes. Make sure the screw on the connectors which pushes the pin on the schrader valves on the cars AC lines are backed out before trying to slide the connectors onto the cars fittings. One of my connectors goes on easily. The other one just snaps on with a lot of pushing and twisting before the connector locks onto the schrader valve. Must be the fitting on the vette as it goes onto outher cars schrader valves without much difficulty.
I would also recommend any type of glasses when working with freon as you don't want to get any in your eyes. If you wear glasses fine. If not a cheap pair of even plastic glasses will stop freon from getting in your eyes.
The connectors are more easily removed without excess pressure. Don't remove the high pressure or red connector with the compressor running. Shut it off and wait for the pressure to bleed off. Can remove the low pressure or blue connector with compressor running as it will be less pressure than with compressor off.
Old Sep 10, 2010 | 10:28 PM
dmarkshark's Avatar
dmarkshark
My big mistake was I had a poor manual. Once I downloaded the other one it was easy.
The original directions were just very poor, especially for a newbie to AC work. I do have glasses as I do a lot of woodworking for fun, so I'll take your advice on that, and once again appreciate the help. By the way, I did check my ac and there was nothing in it, as I thought. Taking it back to the guy who replaced the compressor, only because its still under warranty. After that, I plan on doing my own work.
