Odd question: Engine "alignment"?
Old Sep 10, 2010 | 01:46 PM
AZhitman's Avatar
AZhitman
Default Odd question: Engine "alignment"?
I just installed headers / X-pipe / catback on C5. No issues, relatively straightforward install, and actually much simpler than some other cars I've worked on.
Afterwards, it appears the P side header is closer to the frame rail than the D side (resulting in the O2 sensor touching the frame).
During install, I loosened the motor mount bolt (on each side, separately) and raised the engine 1-2" in order to wiggle out the manifolds and squeeze in in the new headers.
At the risk of appearing a complete moron, here's my question:
Given the design of the C5 motor mounts, which I'm unfamiliar with, can the engine itself be "misaligned" in relation to the frame rails? Or do I just have an oddball header?
Last edited by AZhitman; Sep 10, 2010 at 03:28 PM. Reason: ...typing with boxing gloves...
Old Sep 10, 2010 | 02:14 PM
vettekidc5's Avatar
vettekidc5
During install, I loosened the motor mount bolt (on each side, separately) and raised the engine 1-2" in order to wiggle out the manifolkds and squeeze in in the new headers.
make sure the engiine mount is completely flat against the mounting bracket and frame with a flash light. There IS an alignment pin on both sides of the mount
Old Sep 10, 2010 | 03:16 PM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
It is easy to miss the pin thinking you are fully on the mount and may not be. No, there is no engine alignment process. The whole powertrain including the engine, torque tube, trans, and diff are held by three mounts.
Old Sep 10, 2010 | 03:21 PM
AZhitman's Avatar
AZhitman
OK, so theoretically, I *could* have tightened the mount bolts down with the engine "misaligned" in the cradle, resulting in the engine sitting a bit more to one side, correct?
Old Sep 10, 2010 | 03:24 PM
Eric D's Avatar
Eric D
I would be looking at the driver's side mount to see if the mount is in full contact with the cradle. That would leave the driver's side set a little higher than the passanger side. If that is not the case than you may just have a fitment issue.
Old Sep 10, 2010 | 03:25 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Theres some clearance around the hole on the engine mount bracket. If it were me,, I would loosen up the bolt on BOTH motor mounts and nudge the engine over toward the drivers side and re-tighten the bolts. See if that will give you the correct clearance. It wont be much but it will help a little..
BC
Old Sep 10, 2010 | 03:27 PM
AZhitman's Avatar
AZhitman
You guys are very much appreciated. I'll pop in with an update on the outcome, if only for future reference for others.
Old Sep 10, 2010 | 04:34 PM
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
To Odd question: Engine "alignment"?
