caliper bleeding order to flush brakes?
Old Sep 11, 2010 | 01:42 PM
rustyguns's Avatar
rustyguns
Default caliper bleeding order to flush brakes?
1999 C5 what order do you flush the brake calipers in??
thanks!!!!!!!!!!
Old Sep 11, 2010 | 01:58 PM
OpethMike's Avatar
OpethMike
Rear passenger side, rear driver side, front passenger side, front driver side.
Old Sep 11, 2010 | 02:58 PM
LO PHAT's Avatar
LO PHAT
thanks!!!!!!!!!!
Great! I need to do a brake job on my '98. When can I bring it over to you?
LO PHAT
Old Sep 11, 2010 | 03:13 PM
AU N EGL's Avatar
AU N EGL
Found it makes absolute no difference in which order for any year.
I do RR, LR, RF, LF
Old Sep 11, 2010 | 09:42 PM
vettman10's Avatar
vettman10
Cruise-In II Veteran
I do RR, LR, RF, LF
I Agree!!
Old Sep 11, 2010 | 09:53 PM
00Corvette's Avatar
00Corvette
I do RR, LR, RF, LF
for the best bleed you just work your way starting with the caliper the FARTHEST away from the master cylinder then work your way to the CLOSEST
so RR, LR, RF, LF
Old Sep 12, 2010 | 05:29 AM
rustyguns's Avatar
rustyguns
LO PHAT
heck yeah dude! I am a brakemaster! bring it over!
I do like 3 brake jobs every weekend at the track!
Old Sep 12, 2010 | 05:30 AM
rustyguns's Avatar
rustyguns
I do RR, LR, RF, LF
thanks too all!
Old Sep 13, 2010 | 10:08 AM
LO PHAT's Avatar
LO PHAT
Excellent! I'm going to take you up on this.
Give me a little time to get all of the new parts ordered, and then we'll set something up. I will, of course, bring the beverage(s) of your choice when I come.
LO PHAT
Old Oct 1, 2010 | 12:26 AM
rustyguns's Avatar
rustyguns
LO PHAT
hurry up already!
Old Dec 9, 2010 | 02:52 PM
agm0042's Avatar
agm0042
I heard you need a Tech 2 to bleed your brakes. Any truth to that? I like to avoid the stealership like the plague.
Old Dec 9, 2010 | 03:04 PM
Last C5's Avatar
Last C5
Usually not. But, sometimes after a bleed/flush you end up with a long/softer pedal than you want and either excercising the ABS or having a Tech II excercise the ABS will cure it.
Old Dec 9, 2010 | 05:56 PM
lionelhutz's Avatar
lionelhutz
You're talking about a flush to pump fresh fluid into the brake system. I would think any order would work for that.
Peter
Old Dec 9, 2010 | 08:11 PM
00Corvette's Avatar
00Corvette
Peter
A flush is the same as bleeding except you keep bleeding until all the old fluid is gone. Just do it right and do it once..why vary on something like this?
Old Dec 9, 2010 | 11:14 PM
lionelhutz's Avatar
lionelhutz
A bleed and a flush are not the same unless you screw up and let air get into the system. The furthest to closest rule is to get the air out of the system.
The flush is just to get new fluid in the lines. Doesn't really matter which caliper gets new fluid first.
Peter
Old Dec 9, 2010 | 11:26 PM
Dale002's Avatar
Dale002
Do you need a power bleeder to bleed the antilock brakes?
Old Dec 10, 2010 | 07:09 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Peter
I have an '01, and I flush the brake fluid annually. I've always done it RR, LR, RF, LF......
To caliper bleeding order to flush brakes?
Old Dec 10, 2010 | 10:25 AM
Bull_in_a_china_shop's Avatar
Speedbleeders made it a simple one man job-
Old Dec 10, 2010 | 02:25 PM
Cratecruncher's Avatar
Cratecruncher
I've heard this too! I had a Service ABS code scare a while back and am concerned a shadetree flush is going to leave a lot of oxidized fluid inside the maze of ABS pump and solenoid lines that are isolated from the rest of the system. Those ABS modules are unobtainable at any price now for the '97-'00s.
Old Dec 10, 2010 | 02:38 PM
oh1vette's Avatar
oh1vette
