MAF sensor??
Old Sep 12, 2010 | 08:38 AM
D&A'sDad's Avatar
D&A'sDad
Default MAF sensor??
If I am correct??? big if the MAF sensor is located at the back of the intake (FAST)...mine makes a slight whistling noise every now and then and I heard that there is a MAF sensor relocation kit ?....
Does the intake have to be removed to repair the leak?
Does anyone have any ideal what a fare price is for this repair/reloaction???
Old Sep 12, 2010 | 08:54 AM
WKMCD's Avatar
WKMCD
You have the MAF and MAP sensors mixed up. The MAP is located on the rear of the manifold.
That being said...many people with the FAST have a whistling sound. It seems to be caused by a cast area just inside the throttle body. The was a post a while ago about it.
Here's what Tony Mamo says about it.
http://forums.corvetteforum.com/c5-t...eleration.html
Good luck,
Kevin
Old Sep 12, 2010 | 09:48 AM
D&A'sDad's Avatar
D&A'sDad
Good luck,
Kevin
Thanks Kevin and the whistle is at the back of the intake ( a FAST 90 on a LS2) The tuner isolated the whistle with a stephascope and then could manipulte with his finger....I thought he called it a maf sensor , he's from chicago & I am from ky and we both have been in fl for several years so our dialects are a bit skewed anyway the map sensor needs to be repaired/relocated.....any ideal on how difficult? cost?
Thanks again Kevin for getting me on the right end of the intake
Old Sep 12, 2010 | 10:08 AM
JCamaro's Avatar
JCamaro
Don't some LS6 intake manifolds also produce this whistling sound? I'm sure I remember a TSB post or something about it...I wonder if it's the same thing?
Old Sep 12, 2010 | 12:29 PM
WKMCD's Avatar
WKMCD
You can seal it with some RTV but be very carefull not to get any in the hole in the sensor.
To MAF sensor??
