brake dust
Old Sep 13, 2010 | 09:20 PM
alankb's Avatar
alankb
Default brake dust
Do the ceramic pads, or any pads for that matter, create less dust?
Old Sep 13, 2010 | 10:58 PM
C5FORFUN2's Avatar
C5FORFUN2
Ceramic pads are awsome If they do dust it's not much and not noticable at all. I can go for weeks with my DD without the wheels getting ugly. I used AC Delco ceramic pads with slotted rotors and have had them for several yrs. now and am very happy with them.
Old Sep 13, 2010 | 11:00 PM
jrose7004's Avatar
jrose7004
I use Raybestos Quiet Stops Ceramic and they'll do the trick.
Old Sep 13, 2010 | 11:20 PM
alankb's Avatar
alankb
Default thanks guys
I'll get some. Any vendors on here with pads to fit stock calipers and rotors?
Old Sep 14, 2010 | 12:31 AM
rich goepfrich's Avatar
rich goepfrich
Old Sep 14, 2010 | 01:51 AM
cdkcorvette7's Avatar
cdkcorvette7
Yes, ceramic pads will dust less, however they'll also perform worse... Not bashing ceramics, just warning you. I drove a friends C5 with ceramic pads and the difference between that and my hawk hps is like the difference between a minivan and a corvette. I'm sure they'll work just fine for normal driving but be sure to adjust your habits and brake a little sooner until you get used to them.
Old Sep 14, 2010 | 08:49 AM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
Default Everything is a give and take
Ceramics dust less.. and they also perform less... with ceramics you can add another 20 feet to your stopping distance in a panic stop...
They will stop your car just fine under normal stopping conditions,, but dont ask them to save your life when conditions are out of the normal.
Its pretty simple, as I have said millions of times... they are harder !!! thats why they dust less.. they also have a very low coeffiecent of friction...( they do not grab as well ) No one in my family or anyone who asks me will ever put ceramics on their car. It's your choice, less dust or less stopping ability., We did the testing...
Old Sep 14, 2010 | 09:33 AM
Randy_medion's Avatar
Randy_medion
I heard that Hawk HPS pads grab much better but when they heat up too much, they fade abrubtly without a warning, so very dangerous in a panic stop at 150 mph, because your brakes will get too hot, and ceramic resists heat better, is that true?
Old Sep 14, 2010 | 09:38 AM
Carbotech Adam's Avatar
Carbotech Adam
Supporting Vendor
St. Jude Donor '11,'13
Yes, read this post http://forums.corvetteforum.com/c6-t...s-and-zo6.html
This pad is ceramic Based
Old Sep 14, 2010 | 09:40 AM
SaberD's Avatar
SaberD
im pretty sure ceramic pads will also reduce the life of the rotors in comparison to semi-metallic due to the higher hardness.
Carbotech Adam
Supporting Vendor
Call me 216-780-8825 Carbotech 1521
The Carbotech Bobcat 1521™ is our high performance street compound that is our most successful compound. The Bobcat compound is known for its awesome release and modulation, along with unmatched rotor friendliness. Like our AX™ & XP™ line of compounds, Bobcat 1521™ is a Ceramic based friction material offering minimal rotor damage and non corrosive dust. Bobcat 1521™ offers outstanding performance, even when cold, low dusting and low noise with an excellent initial bite. This compound’s virtually perfect linear torque production provides incredible braking force without ABS intervention. Bobcat 1521™ operating range starts out at ambient and goes up to 900°F. Bobcat 1521™ is suitable for ALL street cars, perfect for your tow vehicle, police cruiser, and has won multiple SCCA Solo 2 and Prosolo National Championships. The Bobcat 1521™ compound has been found to last two-three times longer than OE pads you can purchase at a dealership or national retailer. Bobcat 1521™ compound has also been found to extend the life of your rotors 2-3 times. That’s one of the beauties of Carbotech Ceramic brake compounds. Bobcat 1521™ is NOT recommended for any track use.
Old Sep 14, 2010 | 11:11 AM
HinsonSuperCars's Avatar
0HinsonSuperCars
Former Vendor
From: Birmingham, AL www.hinsonsupercars.com 205-909-9402
http://forums.corvetteforum.com/c5-p...d-special.html
Seth
Old Sep 14, 2010 | 03:30 PM
cdkcorvette7
Not in my experience. I've run the HPS pads on a road course a few times without any problems. That being said, the stock brakes do get very hot with persistent hard braking at track events and you will see brake fade with ant pad. Under normal driving conditions it is unlikely that your brakes will heat up enough for this to be a concern. They do dust a lot though...
Old Sep 14, 2010 | 04:27 PM
AU N EGL's Avatar
AU N EGL
Old Sep 14, 2010 | 05:21 PM
Evil-Twin's Avatar
Evil-Twin
Ceramic brakes cause thermal breakdown because they "are" harder... it takes much more force to stop with ceramics because of the low coefficient of friction.. You don't notice it because you have a brake booster,r but your rotors do...if you drive aggressively , you will put more force on your rotors.. the ceramics will easily discolor the rotors because of the heat that is created from having to push harder on the brake pedal, and ask the booster to assist in the force required to stop , or slow down. You wont see any discoloration on my rotors and these have 70,000 miles on them.
I have nothing to gain or lose by offering you good sound advice... ON the other hand vendors have everything to gain and nothing to lose by selling you them... The word " Ceramics" is a big marketing tool... Ill stick with the word " Safe ". and stay away from the buzz word ceramics.
Old Sep 14, 2010 | 09:59 PM
C5FORFUN2's Avatar
C5FORFUN2
From what I hear, and my experience so far, the rotors wear better.
As far as worse braking, not that I can tell. The brakes actually feel & work better than the semi metalics that were on it. Maybe because of the better rotors??
To the OP,
I have had no problems on my C5 and it's a DD. No discoloration, and it stops better than any other 4 wheel disc cars or trucks I own or have owned, so ?? try it for yourself and I think you will be pleased.
Old Sep 14, 2010 | 10:08 PM
Oldvetter's Avatar
Oldvetter
I took GM Ceramic pads off my C5 early. They warped my rotors and stopped poorly. But they dust VERY little.
I went with HAWK HPS, stopping is GREAT and they still dust less than standard C5 pads.
To brake dust
Old Sep 15, 2010 | 12:43 PM
Big Earl's Avatar
Big Earl
Who makes the Rotors and pads you are running ET?
Old Sep 15, 2010 | 01:43 PM
76 VETTE's Avatar
76 VETTE
Interesting post!
Old Sep 15, 2010 | 01:51 PM
Evil-Twin's Avatar
Evil-Twin
The rotors are Baer Eradispeed two piece rotors.. these are the first set that Baer brought into the country.. These are from Australia. The pads are the stock ACDelco semi metalic. After 78,000 miles, I just replace them, they were the original. Naturally I put the same thing back on.
