Is my BCM hurt?
I have quite a few codes, including B0432, B0503, B0508, B2483, B2527, B2588, B2593, B2723.
In addition, the horn doesn't honk when I hit the lock button on the remote, and the trunk release doesn't work from either the remote or the button on the dash.
I got out the meter and checked continuity from both grounds on the BCM to the battery, they seem ok.
I triggered the horn relay by grounding the pin in the wiring harness at the BCM connector and the horn sounds.
I was able to pop the trunk using the same method as above.
All static and switched power supplies to the BCM have the proper voltage in the proper conditions.
Anything else I should check, or go ahead and buy a new (to me) BCM?
TIA!
TIA!
BC
Still no start, no crank. Car will lock and unlock with the remote now, but again no horn. I didn't try to ground the horn relay wire at the bcm again but I assume that i can still get the horn to come on by doing that.
It's not going to, as long as the B2723 is current. I would inspect BCM connector C1, as the input for the Pass Key detection, and horn relay circuit go to that connector. If the connector looks good, you could check for the key resistance value across pins A3 & B2. Also inspect the receptacle side of the BCM connector C1 for corrosion, moisture, etc.
With BCM reconnected, battery reconnected and key in the ignition I read 0V on B2 and 5.92V or so on A3.
I did not notice any condensation or corrosion on either the bcm or the connector for C1.
Is it possible that the BCM forgot the effective resistance value in the key resistor pellet and needs to relearn?
I would stick the key in the ignition, attempt to start the car, then release the key, making sure not to turn the key to the off position. I would then wait for the security light to turn off, which it never did in the 12-15 min that I waited.
Fwiw, I noticed in the past that there would sometimes be a lag between turning the key to the ignition position and the car starting, sometimes a few seconds.
The good news is that I got the car to start. The bad news is that I had to do some interesting things to make it happen.
I took apart the BCM and studied it carefully, only to find this:
Looks like some input devices got fried... I think they're capacitors, not sure though.
I discovered that I could get the car to crank by grounding pin B7 on connector C3. Unfortunately, it wouldn't stay running because the BCM wasn't communicating via serial communication to the PCM that the fuel pump should stay running.
I scratched my head for a bit, then got an 'aha'!
I whipped out my copy of hptuners and what do you know, there was an option to turn VATS off. I did this, uploaded the new calibration, grounded B7 on C3 again, and voila! The car starts and runs!
I need to buy a new BCM, but in the interim I am going to wire in a momentary pushbutton switch to let the ignition actuate the starter.
Anyway, I thought everyone here might be interested in what I had to do to make the car go, so I'm reporting back.
I took a little break while I was typing, so Lucky beat me to it, but I certainly agree with him.
I had the exact same issue with my 98 Coupe and cleaned and restored normal operation. IF,,, you have corrosion there, you better be looking the board over for more. Especially under components.
Clean it well and give it a try.
OH,,,,,, Solve that water leakage issue before you get more damage
BC
