oil pressure!
Old Sep 23, 2010 | 12:19 AM
printmanjackson's Avatar
printmanjackson
St. Jude Donor '06-'07-'08-'09
I have the stock Z06 pump and when I did my H/C install I shimmed my pump bypass valve .060 and my hot idle is 40 lbs and hight is 60-65 lbs.
Old Sep 23, 2010 | 12:25 AM
Shinobi'sZ's Avatar
Shinobi'sZ
Originally Posted by C6RAPTOR
That is good news. I would like to switch from 20w-50w RP oil to 5w-30w after I change pumps. I track my C6 and have had an oil temp.& pressure problems for two years. The oil temp problem is not a big deal as it was now that I have switched to a RD radiator with oil/water cooler from the other brand that has a oil/water cooler. Do you track the car? 212 deg F is a good street oil temp.
I used my 97' C5 H&C car at HPDE and also on the drag strip with a blower. But I have never tracked the Z06.
I have twin turbos and Ron Davis Rad....plus an Earl's Performance Oil Cooler with -10 AN lines. I think it would do fine at the track....with the current cooling mods it takes 45-60 mins while driving in 100* weather to get to 212*...granted the RPMs are low and not really anything like the track. But I remember driving my stock 97 and 01 around in hot temps and it would get hot quick....both the oil and coolant.
I was seeing 265-270* on my H&C'd 97 on the road course...20 min sessions. All stock cooling parts back then too.
I had an LS6 Katech Ported oil pump...I took it off and replaced it with my Melling because I have two turbos to feed and 1/2" (-10 AN) return lines so I need the extra volume and pressure...but I used it with my prior mods and it worked great...really no different than what you did with yours.
Old Oct 1, 2010 | 01:50 PM
C6RAPTOR's Avatar
C6RAPTOR
I have an extra Melling 10296 High Volume High Pressure pump in the box. $125+ shipping
gary@grbowler.com
Old Oct 1, 2010 | 11:13 PM
greenc5's Avatar
greenc5
Default I have the same issue
Originally Posted by 1stGlance
I have about 80K and recently noticed my pressure droppign down to 15 when hot idling after being run hard. Seems to go up again to 35 + to over 40 when RPMs increase. Starts out about 45 or so when cold.
I have watched engine temps and they have not gone up at all - or just slightly after running hard then sitting in traffic.
Not sure how good or how bad that is..
This is about what I get. 80k miles,, 15 lbs or so on a hot day. normal temps. just took it on a 2000 mile round trip. no problems
