oil pressure!
Old Sep 15, 2010 | 08:02 PM
1sickz51vette's Avatar
1sickz51vette
Default oil pressure!
Hey guys just wondering what everyone else's oil pressure is at idle after its warmed up. My LS1 with 120k miles on it is 23 psi at idle after a few hard runs or being warmed up sitting in traffic. What goes bad on these motors first, is it the oil pump, or pickup screen getting clogged?
Not to sure about the C5's oiling system, thanks!
Old Sep 15, 2010 | 08:32 PM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
Nothing wrong with your pressure. When the engine has 150K+ the oil pressure may start to show lower at low engine speeds. This is due to increase in bearing clearances. Keep driving it, keep up on normal maintainace and fluid changes and you should be able to double the total mileage you now have.
Old Sep 19, 2010 | 02:16 PM
1sickz51vette
Thanks for the reply, a highflow oil pump would take care of those low psi readings though correct?
Old Sep 19, 2010 | 03:17 PM
ZeeOSix's Avatar
ZeeOSix
What weight oil are you running?
Old Sep 19, 2010 | 04:27 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I replaced my 02 ZO6 pump with a Melling Pump when I did my heads/cam/FAST 90 install. Great pressures. The pump produced about 10 more PSI than stock hot and 13-15 more cold.
Replace the OEM timing chain with a LS2 chain while your there. Your inches away from a cam swap so, a mild cam will enhance your driving experiences.. Don't need to go big. Just get a good torque cam and replace your stock springs.
BC
Old Sep 19, 2010 | 04:43 PM
1stGlance's Avatar
1stGlance
CF Senior Moments Member
I have about 80K and recently noticed my pressure droppign down to 15 when hot idling after being run hard. Seems to go up again to 35 + to over 40 when RPMs increase. Starts out about 45 or so when cold.
I have watched engine temps and they have not gone up at all - or just slightly after running hard then sitting in traffic.
Not sure how good or how bad that is..
Old Sep 19, 2010 | 04:45 PM
00Corvette's Avatar
00Corvette
25-30 here @ idle warm 130K roughly
Old Sep 19, 2010 | 04:47 PM
00Corvette's Avatar
00Corvette
yes more than likely but I don't think you should worry. Wait till you're ready to do the timing chain if you're gonna do it.
Old Sep 19, 2010 | 05:14 PM
1sickz51vette
I'm running mobil1 10w40, and speaking of oil...
My car has been sitting for about a month and
when I started it today I heard this "clacking" noise
almost like there was no oil in it! I know that can't be good
for the engine, has this happened to anyone else?
Old Sep 19, 2010 | 05:17 PM
00Corvette's Avatar
00Corvette
yes, valve train noise is a common issue when cold.
just make sure it's "clacking" and not "knocking"
Old Sep 19, 2010 | 06:49 PM
Zaddiction's Avatar
Zaddiction
Just got done putting a melling oil pump in mine now its almost 40 psi at idle when hot and 50 at idle when cold
Old Sep 19, 2010 | 11:26 PM
Eric D's Avatar
Eric D
Yes, it is called piston slap and with the mileage you have it can sound bad, but doesn't really hurt anything other than to make noise. Piston slap will reduce as the engine warms.
Old Sep 20, 2010 | 09:55 AM
C6RAPTOR's Avatar
C6RAPTOR
I want to also install the Melling high flow pump in my LS2 engine.
Could you give details on the oil pump install? Did you use the high pressure spring that came in the pump or the low pressure spring?
Does the pump just bolt on or does the oil pan needed to be unbolted?
gary@grbowler.com
Old Sep 21, 2010 | 08:56 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
NO! You do NOT need to remove the pan. The oil pump is crank driven and mounted on the shout of the crank:
Heres how the oil pick up tube mounts in the pump. Its a cut away showing O ring position:
Old Sep 21, 2010 | 09:29 PM
C6RAPTOR's Avatar
C6RAPTOR
That is really good news. I have been looking for a photo that would show how the tube mounts to the pump and here it is. I see now that the front cover is bolted to the pan.
Where did you get a photo with a cut away showing the O Ring? Will the tube bend down out of the way to slide the pump onto the shaft or do you just rotate the pump up out of the way of the tube and then push the tube up into the pump.
Old Sep 21, 2010 | 10:45 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Someone posted it a while back and I saved it. The tube is held on by ONE screw and the pump can be angled up on one end and the tube down and it will come off no issues.
Theres an improved GREEN O RING that seals much better. Try to find that O ring. I used a melling pump. It was well worth the cash. Make sure that you center the pump on the crank drive sprocket.
Check this out!!
BC
Old Sep 22, 2010 | 09:50 AM
C6RAPTOR's Avatar
C6RAPTOR
http://www.brphotrods.com/mm5/mercha...gory_Code=CNV6
The September 2009 GM High Tech Performance mag. had an article that shows this "oil girdle" from BRP HOT RODS www.brphotrods.com to provide a more reliable seal for the pickup tube's O-Ring. It said it allows both bolt holes in the oil pump to be used instead of just one. Is this true that only one of the two bolt holes are being used to hold the tube to the pump? This is going to be a winter project that I want to have all of my ducks in a row before I start. You have been a big help.
To oil pressure!
Old Sep 22, 2010 | 10:52 AM
Shinobi'sZ's Avatar
Shinobi'sZ
BC
I swapped in a Melling High Volume/Pressure pump...used the red spring that came in it.
My oil pressure at start up...both with 0w-40 and 5w-40 is right around 70. At 212* at idle it is 39-40 psi.
The key for you is does it climb roughly 10 psi per thousand rpms as you rev??? If so then you are fine. Lets say it idles at 23 psi hot...but when then you rev it to 5-6K rpms and it goes up to 50-60 psi. If so then everything is as should be.
Old Sep 22, 2010 | 11:24 AM
C6RAPTOR's Avatar
C6RAPTOR
That is good news. I would like to switch from 20w-50w RP oil to 5w-30w after I change pumps. I track my C6 and have had an oil temp.& pressure problems for two years. The oil temp problem is not a big deal as it was now that I have switched to a RD radiator with oil/water cooler from the other brand that has a oil/water cooler. Do you track the car? 212 deg F is a good street oil temp.
Old Sep 22, 2010 | 01:01 PM
ZZ06's Avatar
ZZ06
sounds ok to me...as stated tho, your car should typically gain around 10psi per 1k rpms. 50+psi cold and at hot idle my car is around 40-43psi....44-46psi while crusing and 60-64psi at WOT....i have a LS6 oil pump.
