dic codes need help please
Old Mar 30, 2002 | 08:39 PM
geezpx's Avatar
geezpx
Default dic codes need help please
for the first time i checked my codes and got more than i planned
if anybody knows what they are i would realy appreciate it,
thank you
my car is a 2000 coupe with 6000miles on it and i have that damed gas guage problem to.
58-smd-b1001-h
ao-ldcm-b2282-h
b2284-h
u1064-h
a1-rdcm-b2283-h
b2285-h
u1064-h
a6-scm-bo851-h
bo-rfa-u1255-h
u1096-h
u1064-h
u1016-h
thank's again
[Modified by geezpx, 6:39 PM 3/30/2002]
Old Mar 31, 2002 | 12:27 AM
ScreaminDemon's Avatar
ScreaminDemon
Default Re: dic codes need help please (geezpx)
It sounds like you may be becoming another victim of a GM Delco battery leak. your getting battery fault codes on rdcm-(right door control module). b2285-battery fault right door, b2284-battery fault left door. u1096-h (history code) loss of communication with IPC. U1064-loss of communication with DCM. 1016-loss of comm. with PCM. You can look up/copy a list of all codes at corvetteplanet.com. You really don't have enough miles for this to be happening, have you had something worked on or disconnected your battery recently? Anyway, erase your codes and check that battery.
Hope this helps.
[Modified by ScreaminDemon, 10:31 PM 3/30/2002]
Old Mar 31, 2002 | 01:03 AM
Gary2KC5's Avatar
Gary2KC5
Default Re: dic codes need help please (ScreaminDemon)
if your considering taking it to the dealer for warranty claim, you might not want to erase the codes!!!
If the dealer see's no codes they say no problem. don't disconnect the battery before visiting your provider of warranty goods!! Disconnecting the battery will erase your proof there is major sh_t wrong!
To dic codes need help please
