another headlight that wont go down
Old Sep 22, 2010 | 11:19 AM
kirks11's Avatar
kirks11
Default another headlight that wont go down
i have done searches and everything but mine seems differerent i have checked my fuzes i still have my lights and everything but i have to switch to high beams to get the lights to go down, the only thing i did different was change from my regualr bulb to my hids......... thank you Jason
Old Sep 22, 2010 | 11:32 AM
lucky131969's Avatar
lucky131969
...and what happens if you plug in the old low beam bulbs to the original harness?.......also, did you recently change to HID's, or is the problem new after the HID's have been working fine?
Old Sep 22, 2010 | 11:34 AM
AU N EGL's Avatar
AU N EGL
Just flash the high beams as you turn the head lights off.
when I put in the HIDs that is what I had to do.
Old Sep 22, 2010 | 11:42 AM
minitech's Avatar
minitech
Actually a common problem with an easy fix.
Your HIDs are 35 watt and the loe beam bulbs you replaced are 55 watt (High beams still are 55 watt) The computer knows to lower the lights when it senses a voltage drop from the 55 watt bulb going out. That is why turning on the high beams for a second works. And why the voltage drop from 35 watt is not the right signal for the computer to tell the lights to close.
Fix is to contact JW Motoring a forum vendor here and put his resistor in line then it work like stock.
Old Sep 22, 2010 | 11:48 AM
kirks11's Avatar
kirks11
O thanks a lot that helps I had these on my Camaro and they worked fine so I figured they would be ok on my vette
Old Sep 22, 2010 | 09:07 PM
JropTop's Avatar
JropTop
Or buy a 55 watt hid kit and do without the resistor
To another headlight that wont go down
