Misfire help! Video attached!
Old Sep 23, 2010 | 08:55 PM
MyEBc5Z's Avatar
MyEBc5Z
Default Misfire help! Video attached!
Recentley I was driving my 02 zo6 and i punched it in 1st gear, when i shifted to 3rd, the motor kind of stopped for a second and then accelerated like normal. Traction control WAS off. When I got down to speed (10-15mph), the car sort of bogged and started to shake heavily. I pulled over and thats when I heard a loud "click click click click" coming from under the car near the motor. I pulled up my codes and there was a "p0300 h c" random misfire code. I checked the clutch and everything looks ok. I switched my spark plugs and wires around, also gapped the spark plugs without success. A local shop (corvette experience) said it sounded like broken lifters. I also checked my valve springs and none are broken. The ticking noise gets louder and faster when engine rpm increases. I will attach a short sound clip soon so please listen and let me know what you guys think it is. Any input will be appreciated! thanks!
Old Sep 23, 2010 | 09:57 PM
Jnape's Avatar
Jnape
You say you switched around wires and plugs. Did you see any burned wires as you have long tubes? Pulling wires off is usually a tug of war that can damage wires in the process.
The ticking is more of a concern as a missfire can be valve train related.
How many miles on the motor? Properly maintained and a stock cam, the C5 valve train is very good.
Old Sep 23, 2010 | 10:45 PM
81c3's Avatar
81c3
I would double check the valve springs. You can have a broken one and it could look ok. Smetimes its broken in just the right spot where it looks like its still in one piece. 2002 Z06 valve springs are notorious for breaking.
If you have a broken lifter its usually at the roller. The problem is that the needle bearings will let go into the engine and possibly cause more damage. You should be able to isolate the cylinder thats missing with a compression check. You can also use a stethascope to try to listen to the cylinders more closely. If you dont see any broken springs, fire it up and try to see if one of the rockers isnt moving like the rest also.
The heads need to come off to r&r lifters. You can do springs with the heads on.
Old Sep 23, 2010 | 11:06 PM
rebelheart's Avatar
rebelheart
I would also take a closer look at those valve springs,it is easy to miss a broken one!
Old Sep 24, 2010 | 12:01 AM
MyEBc5Z's Avatar
MyEBc5Z
37,000 miles. Everything stock accept headers and halltech intake
Old Sep 24, 2010 | 12:11 AM
lucky131969's Avatar
lucky131969
What bank is the noise isolated to? What did the plugs look like on that bank. When you don't have the luxury of a Tech II, so the cylinders can be mapped, plug condition can help isolate a misfiring cylinder. I would at least do a leak down, and another inspection of the valve springs on the bank with noise is in order....it's not uncommon on LS6's.
Old Sep 24, 2010 | 12:47 PM
robsc501's Avatar
robsc501
Hi There,
Sounds like a noisy valve tappit or a broken valve spring, cracked rocker arm.
robsc501
Old Sep 24, 2010 | 03:22 PM
redrckt97's Avatar
redrckt97
classic valve spring symptoms
Old Sep 24, 2010 | 06:20 PM
MyEBc5Z's Avatar
MyEBc5Z
All the plugs looked the same and nobody thinks its a broken lifter?
Old Sep 24, 2010 | 10:05 PM
Dale002's Avatar
Dale002
look at it closer. Lifters do break but as everyone had mention spring are even more common to breakage on this engines.
Old Sep 25, 2010 | 12:38 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
LOOK CLOSELY! Rocker trunnion puked roller bearings OR bent push rod OR bad spring.
Use a mechanics Stethoscope and try to isolate it to a bank and cylinder,
BC
Old Sep 27, 2010 | 07:28 PM
MyEBc5Z's Avatar
MyEBc5Z
Why would I be able to hear the noise under the motor then? If it was a broken valve spring or pushrod, wouldn't I be hearing the noise mostly from the top of the engine?
Old Sep 27, 2010 | 07:34 PM
dougbfresh's Avatar
dougbfresh
Just pull the valve covers and take a look. If you have a compression tester, you can find the cylinder a little faster. I'm voting valve train too.
Old Sep 27, 2010 | 07:43 PM
MyEBc5Z's Avatar
MyEBc5Z
I'll try the compression tester tomorrow and recheck my valve springs and rockers. Let's say its neither of the three, then what would you guys think it would be? Because idk what else would cause a random misfire
Old Sep 27, 2010 | 07:52 PM
dougbfresh's Avatar
dougbfresh
Bad plug or wires, bad injector, bad valves and/or springs just to name a few possibilities.
Old Sep 28, 2010 | 10:31 PM
MyEBc5Z's Avatar
MyEBc5Z
Bump
Old Sep 29, 2010 | 05:49 AM
dougbfresh's Avatar
dougbfresh
Bump
Why are you bumping this, you have nothing to report.
Old Sep 29, 2010 | 06:01 AM
Atok's Avatar
Atok
It's either a broken spring (my guess), damaged rocker, bent pushrod, and less likely a damaged lifter. If it were me I wouldn't run the engine until I pulled the valve cover(s) and found the culprit. Should be easy to find. Definitely valve train related.
To Misfire help! Video attached!
