Lifter replacement help?
Old Sep 27, 2010 | 07:17 PM
MyEBc5Z's Avatar
MyEBc5Z
Default Lifter replacement help?
I'm going to be swapping my stock ls6 lifters for ls7 lifters because one or more is definitely broken. I'm not quite sure exactly what I need to replace other than the lifters when I do this. Can someone recommend things to be replaced such as head gaskets or head bolts. I'm not sure if it's a necessity to replace these
Old Sep 27, 2010 | 07:25 PM
Rob's 73's Avatar
Rob's 73
To replace the lifters you must replace your head gaskets and head bolts. Since you are in there you might as well replace the lifter trays.
How do you know you have a broken lifter?
Old Sep 27, 2010 | 07:33 PM
MyEBc5Z's Avatar
MyEBc5Z
I'm not 100% sure but i checked my valve springs and rockers and they looked fine. A local shop who has corvette experience told me that they were positive it was a broken lifter. I have another thread floating on the tech page about a random misfire which is due to this noise that appeared right when the loud ticking did
Old Sep 27, 2010 | 07:59 PM
YeloFevr's Avatar
YeloFevr
Depending on what's "broken" on the lifter(s) you might end up purchasing a new cam too.
Do yourself a favor and get a set of ARP head studs & thread chaser while you're at it. Clean the bolt holes out, put the studs in, and never worry about them again.
PN: 234-4316 for pre-2004 blocks.
Old Sep 27, 2010 | 09:16 PM
vettenuts's Avatar
vettenuts
Unless its a daily driver, I would disassemble and inspect before buying too many parts. If a lifter is "broken" chances are there are other issues within the block and the question would be can the engine be saved.
Just out of curiosity, if this is a stock motor have you checked for bent pushrods?
Old Sep 27, 2010 | 10:32 PM
corvette8189's Avatar
corvette8189
is it a loud ticking noise?
if it was me i would do-
ls7 lifter, head gaskets, arp head studs, mill/port heads
Old Sep 28, 2010 | 01:46 AM
Last C5's Avatar
Last C5
I just finished dealing with a broken lifter. We salvaged the valve covers, pan, and end plates.
Old Sep 28, 2010 | 08:16 AM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
If you have a broken lifter most likely you will need a cam too. As vettenuts suggested, you need to check push rods first. These are items that can be accessed by pulling the valve covers only.
Check the coils and spark plug wires the very first thing. I had a customer come in that swore his engine had a bad spring, rocker or lifter because of the tick-tick noise. I found that the spark plug wire at the coil pack was not on and the coil was arcing to the plug wire making the noise. Putting the wire back on fixed the miss and the noise.
If you end up with needing lifters, keep in mind that you should not spend extra for "LS7" lifters. All LSx use the same lifters now and they are all the same as what the LS7 uses. Just order new lifters and you will have the best without any undue added cost.
I would also suggest you get a service manual before doing any of the work.
Old Sep 28, 2010 | 07:05 PM
zeevette's Avatar
zeevette
You must have had considerable collateral damage?
Old Sep 28, 2010 | 08:53 PM
MyEBc5Z's Avatar
MyEBc5Z
Loud *** ticking that increases as engine rpms increase. Like I said, I have another thread on here with a high definition sound clip in it.
Old Sep 28, 2010 | 09:04 PM
MyEBc5Z's Avatar
MyEBc5Z
I was leaning towards the arp bolt set also
Old Sep 28, 2010 | 10:43 PM
Last C5's Avatar
Last C5
Lifter roller broke, jammed the cam, broke the timing chain, and from there things went severely down hill.
Old Sep 29, 2010 | 09:18 PM
Coal is King's Avatar
Coal is King
Can you link to your High Def vid, I am having a pinging issue and it is driving me nuts. I am thinking about going with 10-30 oil to see if the noise disappears.
Old Sep 29, 2010 | 09:26 PM
MightyDuc's Avatar
MightyDuc
+1 to the above... i have a ticking sound that seems excessively loud and would love to find out if it needs further attention...
Old Oct 1, 2010 | 11:18 PM
MyEBc5Z's Avatar
MyEBc5Z
http://s919.photobucket.com/albums/a...t=HDV_0150.mp4
Old Oct 11, 2010 | 09:32 PM
paulp's Avatar
paulp
sounds just like my car that just started doing this and im thinking its a lifter also.
Old Oct 12, 2010 | 10:31 AM
BrentC5Z's Avatar
BrentC5Z
This may interest you guys. Been down this road recently myself...
To Lifter replacement help?
