Vert Latches
Old Sep 28, 2010 | 05:56 PM
chris308's Avatar
chris308
Default Vert Latches
Is there anyway to adjust the grab of the tops latches to pull the roof closer to the windshield when closing?
Old Sep 29, 2010 | 07:56 AM
chris308's Avatar
chris308
not possible??
Old Sep 29, 2010 | 03:17 PM
DeeGee's Avatar
DeeGee
Here ya go
Document ID# 656616
2002 Chevrolet Corvette
________________________________________
Folding Top Latch Adjustment
1. Adjust the latch handle (1) for proper fit, by raising or lowering the striker (3).
Important
You should not have to loosen the striker screws.
2. Use a nylon mallet and a drift to punch the striker (3). Punch upward to loosen the striker or punch downward to tighten the striker.
Notice
Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
3. Inspect the striker screws for proper torque.
Tighten
Tighten the striker screws 10 N•m (89 lb in).
4. Loosen the latch handle bolts.
Important
Assure that the latch handle base is parallel to the striker.
5. Reposition the latch handle forward or rearward. To avoid squeaks and rattles maintain a minimum of 2 mm (0.08 in) clearance between latch handle and the latch striker.
6. Tighten the latch handle bolts.
Tighten
Tighten the bolts to 13 N•m (10 lb ft).
Old Sep 29, 2010 | 03:18 PM
Sargevette's Avatar
Sargevette
Good info.
Old Sep 29, 2010 | 06:09 PM
chris308's Avatar
chris308
Originally Posted by DeeGee
Here ya go
Document ID# 656616
Important
Notice
Tighten
Important
Tighten
Thank you sir
To Vert Latches
