Slotted vs. drilled rotors
In the latest issue of Road&Track magazine, the M3, ZR1, Ferrari F430, Jag XKR, and 911GT3 were all compared to their racing counterparts.
In almost every case, the street version has drilled rotors while the racing version has slotted rotors. It seems obvious that the manufacturers include drilled rotors only because buyers "think" they are effective, sporty-looking or ?
I don't blame anyone who feels this way when it comes to choosing rotors for their C5, but like having a fake CAI scoop in the hood or a similarly fake brake duct scoops, I tend to stay away from such non-functional features. In fact, drilled holes in rotors can actually reduce braking performance due to their reduction of surface area (rotor diameter and other features being the same).
Some manufactures do currently (or very recently) ship street cars with slotted rotors; the Cadillac CTS-V and Dodge Viper ACR come to mind, so I believe the trend has started.
Thoughts?
Thoughts?
I agree, just as 20-inch wheels may be perceived by some as looking good. However, even though they can be run on the street, they actually hinder performance - much like drilled rotors.
From: Motorsports Capital of the World..Indianapolis Indiana
IMHO
Drilled---only pretty
Slotted---worth the money and still pretty, I've never had any warp when towing with my truck
The C6 Z06 brakes are cool, thoughI wouldn't want them as they are drilled.
Most high performance kits are only slotted for the track, for a reason: strength and off gassing.
My new ones will be slotted from Corvette Central
IMO Also dubs are dumb!! and stick on Hood scoops (& brake vents) are for high school kids with grocery getters, ricers and trucks.
Thoughts?
Thoughts?
rotors are too thick to be cryoed properly. cryo only works well on thin items, under 2mm thick.
cryoing gray iron will cause more problems then the helping. just use the stock rotor and bed it in properly.
i have read that the primary function of the drilled holes is to allow built up gasses to escape, and the primary function of slots while still offering gas dispersant qualities, is to cut the glaze off of the pad that would build under severe duty. particularly road racing.
true or not?
true or not?
[QUOTE=dklowrider;1575514968]i have read that the primary function of the drilled holes is to allow built up gasses to escape, and the primary function of slots while still offering gas dispersant
In the stone age, brake pads need an outlet for outgassing. With today's technology that isn't needed any more and thus no need to accommodate outgassing
[QUOTE=Joy of 6;1575515884]
I should hope that if all the major racing teams are using slotted rotors, there's a good reason for it, don't you?
I still feel that having "fresh" pad material available when a panic stop happens can be only a good thing. Of course, if you pile on 15,000 miles a year of driving (half or more of it involving heavy braking), then you may not need slotted rotors. I drive my C5 5000 miles per year and my pads last many years at peak efficiency.
a lot of people that track often use plain napa premium rotors. from what ive read, its mostly the brake pad that counts. there is such little gain from slotted or drilled rotors, that its not worth the extra price if you are swapping them out almost every week.
i do have powerslot cryo rotors though
I used to drill the brakes on my GP bikes with a huge number of holes as a weight reduction method. I never noticed any degredation of the braking. The had so many holes in them they would sing when the brakes were applied. The trick is not having consecutive holes in a sweep path.
The bike also weighs A LOT less than a freaking car. The rotors are usually the same size as car rotors though and you get two huge ones on the front.
Point being...bike brakes probably don't generate as much sustained heat when compared to an auto.
SLOTTED FOR PERFORMANCE
DRILLED FOR LOOKS. PERIOD
