C5 Vanity Mirror Lights.
Old Oct 3, 2010 | 06:15 PM
RoninFWB's Avatar
RoninFWB
4th Gear
Default C5 Vanity Mirror Lights.
Is there a way to remove (or disable) the vanity mirror light bulbs? The hinge on the switch side has broken on both mirrors due to heat and the pressure of the switch on the cover. Since the covers put no pressure on the switch , the lights stay on unless I tape the covers down.
Old Oct 3, 2010 | 08:20 PM
lucky131969's Avatar
lucky131969
....remove the bulbs?
Old Oct 3, 2010 | 08:37 PM
m6 c5's Avatar
m6 c5
Put tape where the cover depresses the switch to put enough pressure to cut the lights off.
Old Oct 3, 2010 | 09:07 PM
8VETTE7's Avatar
8VETTE7
Small dab of silicon on the lid where it is supposed to turn off the light??
Old Oct 3, 2010 | 09:25 PM
m6 c5's Avatar
m6 c5
Not a bad idea I think ill try that on mine since I also need to do something.
Old Oct 4, 2010 | 07:38 AM
clif's Avatar
clif
St. Jude Donor '09-'10
1. Remove the visor
2. Unplug the connector
3. Reinstall visor
Old Oct 4, 2010 | 11:34 AM
99 vett babycar's Avatar
99 vett babycar
Have you ever seen the stuff they call "plumber's epoxy" (Home depot and lowes has it as well as most harware stores). the stuff looks like play dough and you knead it together , form it into the shape you need, stick it where you need it and let it harden up. After it drys it can be sanded and painted.Use it to form a replacement for the piece that broke off.
Old Oct 4, 2010 | 07:07 PM
K RIPPER's Avatar
K RIPPER
proclaim rather loudly every time you enter the car "boy o boy I'm sure glad these vanity lights are on " the bulbs will hear and realize that their plot to annoy the chit out of you isn't5 working and they will burn themselves out .out of spite
To C5 Vanity Mirror Lights.
