Valve Stem
Old Oct 4, 2010 | 02:55 PM
scott1974's Avatar
scott1974
Default Valve Stem
Does anyone have an "exploded view" of the tire pressure sensor and how it is mounted. I have a slow leak around one of mine where it meets the wheel. Is their an o-ring I could replace? I have tried tightening it but it always ends up leaking again.
Old Oct 4, 2010 | 03:38 PM
jrose7004's Avatar
jrose7004
I'd try tightening valve stem and replace the o-ring.
Old Oct 4, 2010 | 03:44 PM
scott1974's Avatar
scott1974
Where to get the o-ring? Part number?
Old Oct 4, 2010 | 06:07 PM
my6thvette's Avatar
my6thvette
Just get #9 o-rings from Lowes or Home Depot. They work fine. You will have to take it to a tire shop to get it replaced, since the o-ring fits on the inside of the wheel.
Old Oct 4, 2010 | 06:43 PM
8VETTE7's Avatar
8VETTE7
I think this is the view you are looking for:
http://forums.corvetteforum.com/c5-t...build-kit.html
Then scroll to post #10. Early TPMS had the O'Ring that can be replaced.
Are you are certain the leak is at the TPMS mounting and not an issue with the tire???
Old Oct 4, 2010 | 07:11 PM
scott1974's Avatar
scott1974
Cool thanks! Just what I was looking for.
Old Oct 4, 2010 | 07:15 PM
scott1974's Avatar
scott1974
Yes it s leaking around the valve stem. I checked it with water. I have tried to tighten it up but it is worse than ever now. Off to Home Depot! Thanks for the link with pictures!
To Valve Stem
