Need help with leak
I have an 02 Z06 and a few months ago there was orange stuff under my car (coolant). There was probably a quart. I cleaned it up, topped it off, and there was nothing leaked until last week. I cleaned it up, topped it off, and nothing since.
I read that it is probably the water pump or its seal. I don't understand why it is so intermittent. If there is a leak, wouldn't it leak all of the time. Perhaps only being sensitive to the engine temp creating a higher pressure?
What should my next step be? At idle the car is seeming to heat up higher than normal. I want to do a full coolant flush, but want to fix the intermittent leak first so I don't loose it. Should I just buy a new pump, seal, and coolant and hope that does it?
Thank you,
John
Thank you,
John
As already suggested, get out there right after shutdown with a good light source and find the area it is coming from. Things like knowning if it is coming from the front, side or back of the engine would be good info.
