Weight vs gas mileage
However.......in May I made several runs from Charlotte,NC to Columbia,SC in 2 days.Driving the limit on every road I was able to average 34.3
\db2
carolina
(before you ask....YES it was boring driving a Z this way)
That's why the C7 Corvette will have a 5.5 Liter motor, and the Corvette will be lighter. It will also likely be direct injection. It should make for a fuel efficient combo.
Its also about "weight to power ratio".
Just for example... My car is ~3100lbs, and I have ~525 crank HP. My weight to power ratio is 5.9. If the new C7 Corvette weighs 2800lbs, and has 475HP, the power to weight ratio will be the same, and thus the car should have the same acceleration as my car.
If the car makers can reduce the car's weight then they don't need to produce such high HP motors to get the same performance. They can put in a more fuel efficient motor with less HP and have the same performance as our heavier car's.
Hope that makes sense.
Did I go a little too far with my explanation ? My wife says I do that sometimes.
Toque
Toque
lol nope, not too far, and pretty clear. I guess there's no real way of saying "if you loose x weight, you gain y mpg" too many factors involved maybe. I'm epicly bad at maths though so maybe there is a formula for it. As an example, with your car (hypothetical mpg here) 3100 lbs 525 hp and 27 mpg at 60mph. In that formula, what would happen with, say, 2950 lbs @ 525hp? 27.5 maybe? I'm not trying to be too serious with all of this, just trying to find another small benefit of being lighter
Remember F=ma (force = mass x acceleration)? It takes a certain amount of force to accelerate the mass. The force comes from the engine using fuel. Once the acceleration is done then this doesn't apply any more.
So, if you accelerate a lot then changing the weight will help the most with the fuel mileage. If you cruise on a highway a lot then changing the drag in the car will help the most with fuel mileage.
Peter
Toque
Good thought you have going.
It's too late for me to remember the technical terms, but focusing on rotational weight will yield a greater reduction in mass that needs to be moved and thus yield great weight reduction benefits.
Lighter wheels, tires, aluminum flywheel, etc. Even using the lowest tension valve spring for your application that still provides valve control can add a small benefit.
Problem is though, the cost of weight reduction is generally greater than the savings you receive.
I had an 08 Wrangler with 28mpg and then traded for an 09 V6 Charger with 22mpg and traded that for my Vette with 25mpg, which I'm now happy with
hehehehehe screw the Prius, 25 average and 35 highway is good enough for me
Over all wt should not change the fuel mileage too much. Unless your talking several 100 pounds.
But you should also note that your momentum can also be either used or wasted. While you're cruising along the mass of your car doesn't matter--only drag does. When you climb a hill the mass does matter, but you're also building potential energy (through elevation) which can be converted back into kinetic energy (through gravity) as you go down the other side of the hill, thus saving you fuel. In this case more mass can be better as there will be more momentum to fight aerodynamic forces on the downhill side.
Real-world example: It takes a certain amount of energy to take your vehicle to the top of a hill, but you can get nearly all of that energy back as you descend the other side by turning off the engine. Now this obviously isn't safe, so the second best solution is to coast in neutral. Basically any momentum that is utilized to move your vehicle in place of fuel is energy used, as opposed to energy wasted through your brakes as heat.
It does take more energy to accelerate a greater mass. But you also have more momentum, so you can better recoup that energy. Turn off the engine on the 2,000 lb. vehicle and it'll come to a stop more quickly than the 6,000 lb. vehicle.
Put into practical use, this means that if you go climb a hill (using more fuel on the heavy vehicle) and then go into neutral on the downward side (using the same fuel for both vehicles), the heavier one will speed up more and go further before you have to shift into gear again and go above idle (using less fuel on the heavy vehicle.)
In overall real-life driving, with its starts and stops, winds, hills, curves, etc., the heavier vehicle tends to suffer because the greater energy which has been converted into momentum is wasted as heat, primarily through the brakes.
The mass has no direct effect on the fuel mileage when moving at a constant speed on level ground. There are some small second order effects such as the heavier mass pushing the tires into the ground harder making them a little harder to rotate.
If you go for a highway drive with your can empty and then fill the trunk and back seat for the return trip you won't see much if any difference in fuel mileage unless you live in a hilly area. Hill climbing will cause a heavier car to use some extra fuel because more work has to be done to lift the mass of the vehicle by the height of the hill. Then, every engine and drivetrain has losses which means a certain amount of fuel is used even if the vehicle is idling as you come back down the hill on the other side.
So, the short answer is there is no possible way to relate the mass to the mileage. It will help but I'd believe 100lbs would barely even be noticeable. The amount depends on the vehicle and the driving conditions. Even the same vehicle driven the same route could show a mileage difference between 2 different drivers or on 2 different days.
Peter
