Throwing code P0410
Old Oct 11, 2010 | 12:54 PM
kilingiros's Avatar
kilingiros
Default Throwing code P0410
DTC throwing code P0410, Tried shooting air check valve with WD40, still throwing code. Question, can getting a "TUNE" be causing this?
Old Oct 11, 2010 | 01:16 PM
lucky131969's Avatar
lucky131969
No, but you can have the code tuned out. A P0410 suggests both banks are not responding. While it's possible to have two bad check valves, it's not probable.....rather.....it's the air pump, control valve, or vacuum solenoid. Do a search for "P0410".....you'll find all the troubleshooting you need.
Old Oct 11, 2010 | 08:17 PM
robsc501's Avatar
robsc501
Hi There,
Heres the w/site for additional info.www.obd-codes/p0410
robsc501
Old Oct 12, 2010 | 09:27 AM
kilingiros's Avatar
kilingiros
Originally Posted by robsc501
Hi There,
robsc501
Hi, link www.obd-codes/p0410 doesnt seem to work, please verify....Thnaks
Old Oct 12, 2010 | 10:08 AM
kilingiros's Avatar
kilingiros
Ok, Just finished re-reading various posts related to AIR PUMP. My understabding is that the air pump kiks in when the engine is still cold or just warming up. I throw code P0410 after 30+ minutes ruinning time. PS, only have 9K on odometer.
Old Oct 12, 2010 | 11:14 AM
FASST LN's Avatar
FASST LN
First, check your battery to ensure it hasn't leaked acid everywhere. To check this, you will need to remove the battery and look underneath it for evidence of a battery leak. This happened to me, the acid ate through the air pump vacuum line, and caused my 0410 code. Good luck!
Old Oct 12, 2010 | 08:40 PM
robsc501's Avatar
robsc501
Hi There,
www.obd-codes.com/p0410
robsc501
Old Oct 12, 2010 | 10:56 PM
cdkcorvette7's Avatar
cdkcorvette7
I was just thinking the same thing. With 9K on the clock I'm guessing there's a good chance you still have the original battery right? Definitely check that area and report back. Are you getting any other codes besides the 0410?
Old Oct 13, 2010 | 08:02 AM
kilingiros's Avatar
kilingiros
Nope, replaced the battery two years ago.........
No other code, just P0410...
Old Oct 13, 2010 | 09:22 AM
FASST LN's Avatar
FASST LN
My battery was replaced for leaking by the previous owner. A few years later with me, and it leaked again. I've now changed to some pricey battery.
It takes 5 minutes to check, better to be certain.
Old Oct 14, 2010 | 08:05 AM
kilingiros's Avatar
kilingiros
OK, Will check this weekend, she's sleeping under the covers right now.
To Throwing code P0410
