My plug wires have a pulse... WTF?
Old Oct 13, 2010 | 11:43 AM
DanVetteWarrior's Avatar
DanVetteWarrior
1st Gear
Default My plug wires have a pulse... WTF?
Hello all, let me first start off with saying that I have found this forum to be very very helpful in the past and I'm proud to be a new member of it!
Okay so my 2000 Vette is running great with intake, exhaust, pullies, hypectec and misc. My plug wires are approx 3 months old and there an off brand 10.2mm claiming to be high-end stuff... I know I've should have known better. Anyway, at idle 5 of the 8 wires have a real steady pulse to them. The do not shock me or anything, you can hold them all day if wanted and you can just feel this pulse. The car runs fine idles smooth and gets avg 21 mpg. I've tried swaping the wires to see if changed anything but it didnt. The spark plugs also 3 months old are the NGK iridium's but I cannot recall the gap on them.
Dose anyone know what the hecks going on or should I even be concerned? Any help would be great!
p.s. I did try to search this fourm for an answer before posting. THANKS!
Old Oct 13, 2010 | 12:18 PM
imavettegirl's Avatar
imavettegirl
replace with gm parts.
Old Oct 13, 2010 | 12:45 PM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
If it is running great, don't mess with it. Old saying, "If it ain't broke don't fix it!"
Old Oct 13, 2010 | 01:56 PM
99blancoss's Avatar
099blancoss
Former Vendor
St. Jude Donor '10-'11-'12
describe pulse
Old Oct 13, 2010 | 02:48 PM
dougbfresh's Avatar
dougbfresh
Maybe he's not holding the spark plug wire!
Old Oct 13, 2010 | 03:10 PM
ZZ06's Avatar
ZZ06
x10
Old Oct 13, 2010 | 03:30 PM
manley845's Avatar
manley845
GM SUCK'S!!!!! Use FoMoCo!!!!!!!!
JK
Old Oct 13, 2010 | 07:40 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Hmmmmm,, If you can feel electricity surging thru the wires,,,, You have a VERY unique tallent and may be able to make LOTS of money.
On a more serious note:
1. Please list the wires your running.
2. Are you sure that there properly connected (inserted all the way on the plug and all the way into the coil tower???????
3. If your not sure of the gap you have on the plugs, remove then and verify.
If you can run thru the gears under heavy load (full throttle) and the engine does not misfire, the plug wires are doing their job (for now).
Se if your CHECK ENGINE LIGHT (CEL) ever flashes when your accelerating (means you are expierencing a misfire).
WHY,,,are you only getting 26 mpg?????????? My midly modified 98 got 28-30 MPG easily. Sounds like you need to clean your MAf and or get your car tuned.
BC
Old Oct 13, 2010 | 09:50 PM
lionelhutz's Avatar
lionelhutz
You have not described anything being wrong with the car so just keep driving it.
Peter
Old Oct 14, 2010 | 10:56 AM
rebelheart's Avatar
rebelheart
LOL,That skill would have been very useful back when I was turning wrenches! I wouldnt worry about it if you havent any misfire problems though.
To My plug wires have a pulse... WTF?
