Installing Fast 90..Need help
Old Oct 16, 2010 | 07:21 PM
TriplBlk's Avatar
TriplBlk
Default Installing Fast 90..Need help
Well I did the hard part, at least in my eyes. I got the old intake off and got to looking at the valley to put the low pro bolts and the lines sit higher than the bolts!!
Ive followed this thread--http://forums.corvetteforum.com/c5-tech/1819422-installing-the-fast-90-90-at-0830-hrs-today-2.html
and still have questions like That "relocation point", Dont I just pop the piece back in the same place I took it out of on the old intke? In the thread above its on the front.
Another thing, when I test fir the Fast theres a huge gap between the heads, am I missing something?
Im gonna go continue putting the bolts in while I wait for replies
Thanks in advance!
Old Oct 16, 2010 | 11:07 PM
TriplBlk's Avatar
TriplBlk
TTT- I forgot to add that these pics taken were with the Low pro Valley bolts. I push on the intake ( not in pics) and that gap is maybe half that in the photo's
This seems like it should be cut and dry, If I'm making an obvious mistake, please let me know, Seeing that there's been 19 views already seems like Im doing something dumb?
Old Oct 16, 2010 | 11:18 PM
0331MARINE's Avatar
0331MARINE
From: You know your drunk when you swerve to miss the tree then you realize its your air freshener! Covington Ga
Are you talking about the coolant lines that run under the manifold?
Old Oct 16, 2010 | 11:26 PM
TriplBlk's Avatar
TriplBlk
Yea those lines stick up past the bolts, I didnt know if they created a problem, and I definitely wasnt about to try and tighten down the intake to close up the gap
Old Oct 16, 2010 | 11:32 PM
0331MARINE's Avatar
0331MARINE
Yeah not a good idea. You can tap the lines down carefully or buy the lines that came on the 01-04 Corvettes. I think the DIY you used says somthing about him having to hit the lines with a hammer to make them clear.
Old Oct 16, 2010 | 11:35 PM
TriplBlk's Avatar
TriplBlk
Hit with a hammer? oh lovely thats what Id love to do to my car lol
Ill try that first and hope I dont mess anything up, funny why buddy's 01 Z didnt, go figure
Old Oct 16, 2010 | 11:38 PM
0331MARINE's Avatar
0331MARINE
Just try not to go crazy. They shouldnt have to move very much. Just a tap then check to see if it fits and so on.
Old Oct 16, 2010 | 11:57 PM
TriplBlk's Avatar
TriplBlk
Well thanks man!
Any idea as to why a bunch of ppl put the sensor on the front?
Old Oct 17, 2010 | 12:21 AM
0331MARINE's Avatar
0331MARINE
Originally Posted by powerjunky
Well thanks man!
It makes it easy to get to. I'm going to move mine up front once I pull my FAST to do my head swap.
Old Oct 17, 2010 | 12:33 AM
BHRZ06's Avatar
BHRZ06
A few light taps and you are good to go
Old Oct 17, 2010 | 01:55 AM
bucketlist1957's Avatar
bucketlist1957
I checked your profile. Says you have a 2000 C5. I am getting ready to install a Fast 102 and was just reading the directions. Under the Required Modifications section it says Quote "The rear coolant vent line on 1997-2000 Corvette and 1998-2000 Camaro/Firebird. located in the valley, must be replaced to clear your new high performance manifold. Replace with GM part number 12568478 front only crossover, and (2) 12563325 plugs. Torque Vent Pipe bolts to 12N/m (106 INCH/lbs)". Hope this helps. If others have just bent them down and got by with it. I guess you can try that. I am going to get the recommended parts myself. Hope this helps.
Old Oct 17, 2010 | 02:11 AM
TriplBlk's Avatar
TriplBlk
I realized I may have not been clear becuase The Oil Pressure sensor is moved from behind the intake as well. I meant the MAP sensor. Is It something that goes bad?
I will be doing this
Wow thanks for the Part #
Definitely will use this for a back up
FYI Any more pics I post will be in my thread in the general section
Old Oct 17, 2010 | 02:26 AM
bucketlist1957
No problem. Got another one for you. MAP Sensor 26" Extension. GM GEN 111 (5.7,5.3) applications. Caspers Electronics part # 109080. WWW.CASPERSELECTRONICS.COM
1333 Wilhelm
Mundelein,Illinois 60060
Phone # 847-247-0484
Fax # 847-247-0483
sales@casperselectronics.com
Old Oct 18, 2010 | 04:14 PM
TriplBlk's Avatar
TriplBlk
Ok ran into another problem
You guys know how the Ls1 TB has the coolant line that runs through it. ls2 Doesnt,no big Right? Well I go to run the line from the radiator to the Valley lines. Too short!!
So then I go to buy a line to fit the Valley lines, Get home to the install and the Inner Diameter is Different on the radiator fitting than the Valley line!!! WHYY!!!!! This makes it so complicated.
If anyone has a fix or anything, please let me know !
Old Oct 18, 2010 | 07:24 PM
TriplBlk's Avatar
TriplBlk
UPDATE!!
Fixed the coolant line problem...Now onto the BIGG problem
I Started it back up later and the sound isnt as noticable...but the codes I have are insane!!!!!
P0300 Engine Misfire Detected
P1120 TP Sensor 1 Circuit
P1220 TP Sensor 2 Circuit
P1431 Fuel Level Sensor 2 Circuit Performance
P1514 TAC System MAF Performance
P1516 Command vs Actual Throttle Position Performance (TAC Module)
Someone be my savior lol
Old Oct 18, 2010 | 07:47 PM
lucky131969's Avatar
lucky131969
UPDATE!!
Do you have the stock air intake accordian connected to the 90mm TB? Did you use an adapter for the TPS? If so, did you check it with a meter (wire for wire) before connecting?
Old Oct 18, 2010 | 09:00 PM
TriplBlk's Avatar
TriplBlk
Yea Everthing is connected. Adaptor as in?
Throttle body harness from Casper yes....
So Far the gain isnt as nice as I expected, but Im praying its all these codes..
To Installing Fast 90..Need help
Old Oct 18, 2010 | 09:11 PM
lucky131969
Ok, I didn't know you could get a small TB tube to seal properly to a 90mm
....and gains? I wouldn't even drive it with those codes.....let alone worry about gains. So again, the question...did you check the harness with a meter before connecting it? Theses harnesses are notorious for being pinned up wrong.
Old Oct 18, 2010 | 09:30 PM
TriplBlk's Avatar
TriplBlk
Small TB Tube?
The accordian Hose fit over just fine actually lol
ANd your right about what to worry about...I havnt checked it, I ran outta light but what do you mean by "pinned up wrong"
I have a volt meter, so what do I look for?
Old Oct 18, 2010 | 10:05 PM
lucky131969
Small TB Tube?
I must have it mixed up with some other issue..sorry for the confusion.
