Yella Terra
Old Oct 17, 2010 | 11:26 AM
Jim in Mich's Avatar
Jim in Mich
Default Yella Terra
Does anyone have Yella Terra 1.7 rockers with the Competition Cams double valve springs with titanium retainers and 10* locks? Was wondering if there is at least .060 clearance. Would hate to order them, pull everything apart and not be able to use them and have to send them back.
Old Oct 17, 2010 | 12:36 PM
vettenuts's Avatar
vettenuts
I have them on AFR's with the AFR double spring. Unless you are machining for a larger OD spring, I wouldn't think you would have a problem. The key is to set the wipe correctly which is done with rocker height. You may also need more shim then provided so you have to check. Then measure for pushrods.
Old Oct 17, 2010 | 05:57 PM
7LitreC5's Avatar
7LitreC5
I am running the Comp 921 double springs with L92 Yella Terras and they work fine.
To Yella Terra
